My_Ref Fremen Edition - Beta build/Fine tuning
Old 17th June 2012, 09:26 AM   #1001
bcmbob is offline bcmbob  United States
Thanks, I'll give the nx a try. Did you install the alternate compensation scema. That makes a big difference on the FEs. I'll try to get it on the V1.3 amps sometime today.
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 17th June 2012, 09:30 AM   #1002
Thanks, I'll give the nx a try. I'm not sure how much of the alternate schema is already on the V1.4 but I'll try to install it on the V1.3 amps later today. It made a big difference on the FEs.
Bob M.
Old 17th June 2012, 09:35 AM   #1003
PreSapian is offline PreSapian
yes, the difference is quite noticeable isn't it? i can see how most people would prefer the alternate placement but for me inner harmonics take priority and i've actually grown quite fond of the 'soft' myref bass
Old 17th June 2012, 09:44 AM   #1004
Sory, I wasn't clear in my response. I was refering to the alternate compensation mod. We are going to have to give them their own names.
Bob M.
Old 17th June 2012, 10:30 AM   #1005
hehe agreed.
Old 17th June 2012, 11:56 AM   #1006
Found an old BP-150 board with surface mount spots. Here's my little down and dirty production showing the simplicity of the process.
https://www.box.com/s/696f9e6ddd503832495c
This one is a little plump, but will work just fine. Some solder wick painted with flux works great to remove any extra solder.
P.S. Look out Spielberg!!
Bob M.
Old 17th June 2012, 12:08 PM   #1007
metal is offline metal
metal's Avatar
Nice work, though, you need someone to hold the tweezers for you to prevent the resistor moving, hence, you have better control on the soldering process, in other words, the amount of solder. You cave me a push toward trying that by myself.
Thanks for the video :- )
Old 17th June 2012, 12:08 PM   #1008
ClaveFremen is offline ClaveFremen  Italy
Reality first!
ClaveFremen's Avatar
Nice video, Bob
Only a suggestion wet (much) less the point, it will avoid that excess of solder.
A good smd solder joint should have only a tiny amount of solder.
Interesting link with lots of pics of excessive solder:
http://www.technolab.de/_en/solderdi...sivesolder.php
Dario
ClaveFremen "Bailando Salsa en el Sietch" - My_Ref FE 12th GB is open
Old 17th June 2012, 12:20 PM   #1009
O.K. So it's "Fat" not plump. .........And I wasn't shaking - just zeroing in on the exact center, with quick minute adjustments.
Bob M.
Old 17th June 2012, 01:22 PM   #1010
billo44 is offline billo44  United Kingdom
billo44's Avatar
Default SMD
Thanks Bob and Dario,
Advice and encouragement much appreciated.
Looks do-able!
You will see how I get on later....
Thanks again
Bill
My_Ref Fremen Edition - Beta build/Fine tuningHide this!Advertise here!
My_Ref Fremen Edition - need help on PCB evaluation ClaveFremen Chip Amps 450 23rd October 2013 03:38 PM
fine tuning of tapered TL...can i do this??? mondogenerator Multi-Way 6 8th December 2009 05:05 PM
F3 fine tuning ZUM911 Pass Labs 5 31st January 2008 09:14 PM
Orion fine tuning PT914 Multi-Way 6 14th February 2005 09:11 PM
