Does this make sense?
Old 25th September 2003, 01:12 PM   #11
millwood is offline millwood  United States
Account Disabled
Originally posted by Illusus
Oh my... inversed input is just a typo, thanks for pointing it out, I may have followed it during construction. With that reversed, do all the values look good?
it will work if you correct the input error.
The chip is surprisingly fault-tolerant. I ran it with just two resistors and it worked flawlessly. I used much lower resistors (20k/1k combo) because that's what I had. No problem whatsoever. The key here is the ratio between the two, not their absolute value.
There is no reason that yours wouldn't.
Old 25th September 2003, 01:59 PM   #12
JOE DIRTŪ is offline JOE DIRTŪ  Canada
JOE DIRTŪ's Avatar
Illusus...you are off to a start with a design and asked questions......dont feel bad about that as we all make mistakes in venturing into new things .....your other design criteria should be your input to this amplifier as you have used a low impedance so now you should look at what source will be providing the signal and whether it is suitable or else you will need to adjust the input impedance of your design
just food for thought....keep up the good work!!!
DIRTŪ
Does this make sense?Hide this!Advertise here!
Does USB->I2S make sense ? percy Digital Line Level 20 24th March 2009 01:23 AM
Linear voltage regulator: how to make good use of "sense" and "ground sense"? NeoY2k Analog Line Level 7 6th September 2008 11:35 PM
TL, does this now make sense? Madmike2 Multi-Way 2 8th May 2005 02:39 PM
Does this make sense ? 00940 Solid State 7 27th March 2004 09:29 PM
does this make sense? nosegoblin Solid State 9 14th February 2004 02:19 PM
Copyright ©1999-2017 diyAudio
