| Chip Amps Amplifiers based on integrated circuits |
I recently received my LM3875's, this is the schematic I compiled from some of the ones floating around. Will this work?
#2 | |
#3 |
It should do. It is virtually the same circuit that I started with except that I used a 47K in place of the 18K.
The truth need not be veiled, for it veils itself from the eyes of the ignorant. |
#4 |
ehm ... this is inverted amp technologie (
) but the input is on the non-inverted input from the chip ..so it's a no go |
#5 |
Swap the inputs, otherwise it is a power Schmitt-trigger instead of a power amplifier.
#6 |
Electrons are yellow and more is better!
Illusus, wether you are skilled or not check allways the datasheet and application notes. There you have all info for using the IC. If you don't understand some parts we will happily help you.
http://www.national.com/an/AN/AN-1192.pdf http://www.national.com/ds.cgi/LM/LM3875.pdf I know my post is rather boring but National happens to have one of the best datasheets and application notes, very much worth reading.
/Per-Anders (my first name) or P-A as my friends call me |
#7 | |
Account Disabled
it couldn't have worked, as the inputs are swapped. it seems that you wanted an inverting topology but with different resistor values. the resistor values will work, but the topology will not. |
#8 |
Besides swapping inverting and noninverting inputs, and setting it up for large DC offset by not compensating for bias current, you've also got a situation where disconnecting the speaker could remove the input ground reference.
Bad circuit all around. Use the app notes as P-A suggests. Those National guys are pretty smart and actually know how to use their chip.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#9 |
Oh my... inversed input is just a typo, thanks for pointing it out, I may have followed it during construction. With that reversed, do all the values look good?
I have read the national sheet, it's not that boring . I ask because I just want to make sure everything is ok, I'm very unsure of my "skill". Someone once told me there are no stupid questions, I hope he didn't say that to make me look stupid.The reason I decided to compile a couple of suggestions before I start is because it seems that on every "look at my igc" thread the changes I included now, are suggestions. I have been reading entry level elctronics text books and plan on taking some night classes as I become more and more interested. I am starting to understand schematics not just copy them. I still don't understand much but I do get excited when I look at a simple cuircuit and can follow it. It feels good knowing which component does what, I do have a problem with how much it does of what it's doing (values)....so bear with me guys one day I may even have some noteworthy input not just annoying questions. |
#10 | |
I do agree that for anyone starting out, it is best to stick with a proven circuit.
| Does USB->I2S make sense ? | percy | Digital Line Level | 20 | 24th March 2009 01:23 AM |
| Linear voltage regulator: how to make good use of "sense" and "ground sense"? | NeoY2k | Analog Line Level | 7 | 6th September 2008 11:35 PM |
| TL, does this now make sense? | Madmike2 | Multi-Way | 2 | 8th May 2005 02:39 PM |
| Does this make sense ? | 00940 | Solid State | 7 | 27th March 2004 09:29 PM |
| does this make sense? | nosegoblin | Solid State | 9 | 14th February 2004 02:19 PM |
| Page generated in 0.10223 seconds (77.57% PHP - 22.43% MySQL) with 11 queries |
