More Power out an TDA7294/3
Old 24th September 2003, 01:40 PM   #1
tab30 is offline tab30  Germany
Question More Power out an TDA7294/3
What do You think of this arangement ?
Will it work proper ?
I want use TDA7293 and insed of BD 249 / 250
Sanken Like SA1494 / SC3858
The value of Resisor at the Output of the IC is 0,18 Ohm.
The Picture is from:
http://www.freak-audio.de/amp01_anleit.html
Old 24th September 2003, 01:57 PM   #2
millwood is offline millwood  United States
Account Disabled
a similar circuitry was discussed somewhere here and at least one forum reader tried it without much success.
It is a classic example of expanding opamp's current output capabilities and you may find it in textbooks. So it works first of all.
The bad news, per my simulation, is that it doesn't work well in that THD is very high. I used a 541 driving mje15030/31 and at 4ohm, THD is in single digital. Not something to write home about.
Also, 0.18 may be a little too small as you need 3+amps from the IC for the transistors to start to conduct and contribute.
In a nutshell, if you need more current output capabilities (to drive low impedance speakers) and don't mind lower sound quality, it will do for you. Otherwise, you may want to take a different route.
Also, the circuit is unstable with mosfets (I tried 540/9540), in case you are wondering.
Old 26th September 2003, 09:56 AM   #3
sangram is offline sangram  India
The 7294 datasheet has a nice circuit using supply voltage boosters to increase power output beyond nominal output rating. Very interesting stuff.
Also you can consider running two or more amps in bridge/parallel configuration...
Running in the way you have mentioned introduces a lot of crossover distortion. Not recommended.
Old 23rd February 2005, 01:10 PM   #4
eborgard is offline eborgard  France
The best you can do is what Linn apparently does on the Chakra twin:
-use current sensing resistors (O,2 Ohms?)in the output stage power supply pins ONLY (and not on the "signal" power supply)
-drive from the voltage drop transistors to boost the output current.
with this configuration, the TDA provides the current up to 3 amps, then the bipolars will provide the extra current.
Distortion will be that of the TDA up to 3 amp outputs, and then probably be slightly better than that of the TDA at higher current due to the reduced output resistance
From the chakra twin specs and reviews, it seems very effective, and I am currently implementing it
Old 23rd February 2005, 03:13 PM   #5
danyel is offline danyel  Romania
Why don't u use 2 ic's?U can get a clear 150Watts?
Old 23rd February 2005, 03:13 PM   #6
I've tried it and it works smoth.Becouse of the lack of big speakers i made an stereo amplifier with only one 7294 per channel and it works just well.I have a little problem with the tone controller(tda1524):it's a little bit noisy,probably not grounded well(no hum but a little fuss).Still working on it.
Old 23rd February 2005, 06:09 PM   #7
Why has Linn moved from 3 ICs to one?
Just for marketing? Or because there is an impact on the sound (probably on THD at high voltage swings)?
Old 24th February 2005, 03:01 PM   #8
driver is offline driver  Latvia
I used a driving KT819/818
http://u-sound.narod.ru/files/tda7294subamp.pdf
Old 24th February 2005, 07:54 PM   #9
The booster of the "emitter follower" type will generate crossover distortion and you will loose the benefit of the monolithic output stage.
The CFP configuration with current sensing resistor inthe power supply section gives much better results. It will allow:
-an ouput current coming from the TDA7293 only , for current up to 3 amps (hence same crossover distortion as TDA7293)
- an additional output current coming from the bipolar output stage for currents greater than 3A, the TDA7293 will provide abit more than 3 A, and the bipolar will provide the rest.
( And because Vs- < PVs- and Vs+ > PVs+, the IC won't blow )
Old 6th June 2015, 11:01 PM   #10
zanden30 is offline zanden30  Netherlands
@driver and @eborgard: Eborgard is quite right. But if you decrease the R7 25 Ohm tot 0,6 Ohm and decrease the emitter R's from 0,25 tot 0,15 Ohm, it will work much better.
See for the calculation: http://www.diyaudio.com/forums/chip-...ml#post4345628
Dr Frost proposes 6,8 Ohm for R7, but I proved with a calculation that that is even too much, let alone 25 Ohm.......
More Power out an TDA7294/3Hide this!Advertise here!
eBay TDA7294 kit + Parts Express Buyout 32V CT 200VA Toroidal Power Transformer? IsleOfMan Chip Amps 7 19th February 2009 09:44 AM
tda7294 current, power transformer selection rbruss82 Chip Amps 1 15th August 2006 08:39 AM
tda7294 current, power transformer selection rbruss82 Solid State 1 14th August 2006 08:21 PM
Copyright ©1999-2017 diyAudio
