TDA7294 + Power Transistors AMP (TDA7293 to come also) - Page 18 - diyAudio
Old 30th June 2013, 07:17 PM   #171
3 pairs per channel and bridged amp
Old 30th June 2013, 10:06 PM   #172
godslayer about 200W single or about 800W in bridge.
sameer x1 also a nice POWERFULL one.
Old 1st July 2013, 03:56 AM   #173
Thank you
Old 1st July 2013, 09:44 AM   #174
Could anyone please explain the how is this being powered?
I'm new to this stuff, so...
Thanks anyways.
Old 4th July 2013, 05:17 PM   #175
usman... i use 25-0-25 transformer(125VA), one
15amp bridge rectifier, and 4x4700uF caps.
Old 8th July 2013, 03:43 AM   #176
this thing really gets better!, isit sort of stabilizing or something ?
this the so called burn in?
the first clone i made didnot improve much the first ten or more hours
donīt know now, have to listen to it.
But this one when augmented with the transistors, started sounding kind of bad and was having trouble with a bad speaker, after changing to another bigger and more power withstanding speaker, left it for two hours full volume from laptop, then came and lowered for half hour and again full for four hours it got better and more today.
would like to measure but dont have the equipment
Old 8th July 2013, 06:22 PM   #177
what did you do martin martinez, in my experience with several of these amps over that last 5 years is that they sound awesome from 1 second and the same 5 years later??, are you using some old caps that are leaking or something??
But im glad that some of you are finally using this AMP, it is still the best i owned
Old 8th July 2013, 08:09 PM   #178
Thanks for your comments! and sharing.
This clone sounded not to good until reinforced with the transistors
and- also rearranged cables, grounds included,-
at every time i came to listen, turned it off discharged caps
and moved this and that ,turn on and listen
loud and quiet, get away some more time... etc.
Old 11th July 2013, 08:13 AM   #179
Mihkus is offline Mihkus  Estonia
Mihkus's Avatar
I was going to do this with my single sided LM3886 PCB and added 2 pairs
Is it even possible? seems like it is but i belive it may sound not as good
If it sounds good I will do it it will cost around 80€ just to make 2PCBs with mid qualty
components... Click the image to open in full size.
how to take screenshots
ITS NOT FINISHED BOARD.
Few more things to do but, heall yeah its going to kick butt, at least i think
Old 14th July 2013, 04:57 PM   #180
Ahan, could i please have a scematic for the PSU?
More Power out an TDA7294/3 tab30 Chip Amps 13 9th June 2015 12:52 PM
TDA7294 TDA7293 LM3668 Spice micijanus Chip Amps 2 17th August 2014 03:50 PM
Question about TDA7293 and power module Rotus623 Solid State 11 3rd October 2010 04:59 PM
Differences between TDA7293 and TDA7294???? Leolabs Chip Amps 1 22nd December 2006 10:12 AM
Copyright Đ1999-2017 diyAudio
