TDA7294 + Power Transistors AMP (TDA7293 to come also)
Old 2nd May 2014, 10:45 PM   #351
geraldfryjr is offline geraldfryjr  United States
I just found this for those of you whom keep asking about using more output devices,
Amplificator cu TDA7294 si tranzistori | RoElectronica
I had covered those type of questions in a very early post in this thread.
I have not been able to get any of the output devices used as of yet so I have not tried this design, But I do plan to sometime in the future.
Cheers!!
jer
Old 3rd May 2014, 09:53 AM   #352
dr frost dk is offline dr frost dk  Denmark
geraldfryjr i actually think that is one of the designs i stated out with a LONG time ago, but sounded like crap due to missing "sync" resistor
Old 3rd May 2014, 10:29 AM   #353
Yes, I noticed that the resistor was missing!!!?
Hmmmm...............
jer
Old 16th June 2014, 12:29 AM   #354
JaanusJ is offline JaanusJ  Estonia
Bumping this thread, cause my amp kicked out some flames. I'm thinking lack of cooling to be the cause.
Anyway, new amp is almost ready.
But I have an idea of mounting the transistors on a separate radiator. Using actually 3 radiators in total, 1 for the chips and 1 for each transistor pair.
I do like to make things interesting, so will 2 of these be any good for the transistors?
ARCTIC | Alpine 20 PLUS CO | Intel CPU Cooler for Quietness | wide compatibility | quiet air cooling solution | efficient heat transfer | best performance | low noise | server cooling
Oh and is it still okay to mount the transistors away from the board using wires?
Old 16th June 2014, 07:13 AM   #355
I'm surprised it survived until the middle of June !
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 16th June 2014, 04:22 PM   #356
Well tbh, it did break a while ago. But thats all part of the diy process, I'm not worried, i like soldering
Old 17th June 2014, 08:32 AM   #357
isidore kanerusine is offline isidore kanerusine  Zimbabwe
I've used a 30-0-30vac transformer and maintained an 8 ohm load and I have no problems, coz remember its a bridged amp and its already driving close to its maximum power, so if you increase load the more strain you're adding, more heat dissipation, so whatever load you add, maintain 8 ohms.if u want to drive more speakers try series- parallel connections
Old 19th June 2014, 02:10 PM   #358
hi guys, is there anyone with a good midrange amp schematic and PCB layout?
Old 28th June 2014, 01:26 PM   #359
dean95 is offline dean95
can someone tell me the heatsinks characteristics of the tda7294 and the two transistors ( 2sa1943 & 2sc5200) thanks a lot..
Old 3rd July 2014, 01:58 AM   #360
zanden30 is offline zanden30  Netherlands
The 6,8 Ohm implies that the slew rate of the chipamp becomes critical. The chipamp only delivers around 100 mA output (makes 0,7 V over BE of the boost transistors).
It would be better if the Chaipamp delivers half its capacity, thus 3A. When assuming Ube = 0,7 V this implies that the R = 3/7 Ohm = 0,3 Ohm. If you use 0,5 Ohm, the chipamp will deliver 1,4 A and the boosters do the rest. This implies far less cross over distortion. I would like sombody test and measure the distorion.....
TDA7294 + Power Transistors AMP (TDA7293 to come also)Hide this!Advertise here!
More Power out an TDA7294/3 tab30 Chip Amps 13 9th June 2015 12:52 PM
TDA7294 TDA7293 LM3668 Spice micijanus Chip Amps 2 17th August 2014 03:50 PM
Question about TDA7293 and power module Rotus623 Solid State 11 3rd October 2010 04:59 PM
Differences between TDA7293 and TDA7294???? Leolabs Chip Amps 1 22nd December 2006 10:12 AM
Copyright ©1999-2017 diyAudio
