TDA7294 + Power Transistors AMP (TDA7293 to come also)
Old 20th May 2013, 01:10 PM   #101
kebbz is offline kebbz  Serbia
My multimeter measures :
2-200 V range :40-400 Hz
Shown value : average rate (in case of RMS sinus sign)
Meh, so at the end the amp power might me even less than its measured. At the end it will be 100 Watts instead of anticipated 1000W
Old 21st May 2013, 12:27 PM   #102
mashoni23 is offline mashoni23  Kenya
Default Emitter resistor problem?
Hi All - i started building this setup but i ran into difficulty in sourcing for the 0.15 emitter resistors and could only find 0.27 resistors ,can this still work ?
Component list: (1x AMP)
1x 680 (680R) Resistor
1x 10K Resistor
3x 22K Resistor
1x 6.8 (6R8) 5W Resistor
2x 0.15 (0R15) 5W Resistor
2x 10uF 50V Capacitor
2x 22uF 50V Capacitor
1x 1uF 63V MKT/BiPolar Capacitor
1x TDA7294 Chip AMP
1x 2SA1943 PNP Transistor
1x 2SC5200 NPN Transistor
Schematic:
NOTE: 6.8Ohm resistor is a 5W
Old 21st May 2013, 03:37 PM   #103
dr frost dk is offline dr frost dk  Denmark
yes everything up to 0.5Ohm will work (larger will also work), but remember the more Ohm the more heat/power is lost in the resistors, the 0.15 i use is because i have a "case" of them and want to keep all the amps i make the same
Of course you can use to little and risk the chance of blown output transistors, but so far with 0.15Ohm i have played 2 OHM 500W speakers up to their limit without any problems.
Old 21st May 2013, 09:17 PM   #104
thanks a lot man i appreciate it
Old 24th May 2013, 01:16 AM   #105
Default dissapointment
unfortunately the sound was disappointing,it sounded nothing close to all that has been claimed ,i think the power out put was just 80Watt .the transistors look like this picture from the net....could they be fake?
Old 24th May 2013, 09:26 AM   #106
they look genuine.
regards Andrew T.
Old 24th May 2013, 10:09 AM   #107
did you hook up the transistors properly, if you only get about 80W than that sounds like only driver is the TDA729x
Old 24th May 2013, 11:05 AM   #108
Hey mashoni23, before the bridged amp I've built this one, here is the image of the finished module and the PCB layout, hope it helps. My output transistors aren't even the same one is japan and the other who knows, but it was hooked up and tested and sounded just fine.
Old 24th May 2013, 11:15 AM   #109
just to be clear, they extra power stage is not dependant on C5200/A1943 i just choice them because of the power and because the set are newer (2011)
Old 24th May 2013, 09:26 PM   #110
martin martinez is offline martin martinez  Mexico
So we could just adapt many types of bipolar pairs?
depending on the specs.
TDA7294 + Power Transistors AMP (TDA7293 to come also)Hide this!Advertise here!
More Power out an TDA7294/3 tab30 Chip Amps 13 9th June 2015 01:52 PM
TDA7294 TDA7293 LM3668 Spice micijanus Chip Amps 2 17th August 2014 04:50 PM
Question about TDA7293 and power module Rotus623 Solid State 11 3rd October 2010 05:59 PM
Differences between TDA7293 and TDA7294???? Leolabs Chip Amps 1 22nd December 2006 11:12 AM
Copyright ©1999-2017 diyAudio
