| Chip Amps Amplifiers based on integrated circuits |
Hi all
First of all, I am quite new to diy builds, so I started with a diy kit from chipamp.com. 2 x Dual mono (LM3886) for driving my System Audio Ranger Master speakers in bi-amp. The amps sound great, and I am very pleased with the result. My problem is, that I hear a small scratch whenever i skip or pause a track. I have tried with several sources, and the noise occurres whenever the signal is cut. Do you have any suggestions? I have tried to search the forum, and haven't been able to find a thread solving my problem. Please direct me to a thread if you have better search words than me. Best regards Morten Attermann Holst |
#2 |
The Source is probably sending a pulse when the Play and Mute conditions are swapped.
regards Andrew T. |
#3 |
Thanks for the reply.
I have had a Rotel amplifier connected previously, and that did not make the noise. So I don't think the source is at fault. /Morten |
#4 |
I don't think the chipamp pcb has DC blocking on the input, your old Rotel will have.
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#5 |
Add a NP capacitor in the RCA inputs like 3.9uf or 4.7uf and listen if the noise goes away.
| Signal tube noise! | M Gregg | Tubes / Valves | 15 | 16th November 2010 07:18 PM |
| Noise from new caps in signal path, please help! | rg12 | Parts | 7 | 27th August 2010 02:13 PM |
| Signal Indicator LED Noise? | turantual | Solid State | 4 | 15th August 2008 11:13 AM |
| Clicking noise when other appliance is turned on | ivoa | Solid State | 6 | 10th July 2008 01:47 PM |
| noise floor w/ and w/o input signal | gearheadgene | Class D | 18 | 6th September 2006 08:04 AM |
| Page generated in 0.07111 seconds (75.12% PHP - 24.88% MySQL) with 10 queries |
