Old 4th February 2012, 10:16 PM   #1
elaar is offline elaar  United Kingdom
Default A bit of expert advice required for all these gainclone components
Hi all,
About 5 years ago I decided to build a gainclone. Instead of just building a simple design and perhaps later tweaking it, it seems I kept changing my mind on the design and where I had more money than sense, kept buying more components and yet never completed one.
Since then, repairing arcade boards has been my main hobby, but I would really like to actually finish this. I have 2 monoblock cases ready (which took a while to make and I found out that drilling into 3mm brushed stainless steel was near on impossible), with transformers and was hoping people could suggest a good way of using all of the components I have hoarded.
In a file, I have all of the print outs of designs I purchased the components for, these include Carlos Filipe's buffered inverted GC, regulated snubbed PSU v1.1, non-inverting v4, unregulated psu mkIV and a few more to boot.
I also have multiple PCBs, mostly from unisonus, LM3886, LM4780 and preamps
The transformers are 225v encapsulated 25v*2, and I plan to use these with B&W 8ohm, and somehow interface with the PC, but probably create a seperate preamp with buffer/volume control. I don't require a large output wattage as I live in a flat.
The components I have disgracefully amassed are:
4 x LM4780TA (and unisonus boards, although these don't have to be used)
2 x LM3886
2 x OPA627 (and 4 unisonus pre amp boards)
3 x OPA637
18 x 2200uF 50v Pana FC caps ( I was going for a low impedance PSU)
4 x LM338 5Amp regs (for the regulated designs)
2 x Audyn 4.7uF huge polypropylene caps
+ All the associated resistors/chokes etc for alot of designs.
With all of these components, and the advance of designs in the last 5 years, what would you do with these? I could do with putting the rest on ebay for some extra beer money.
Sorry this post is a bit long, any advice is gratefully received as always. I will continue to scour the forum posts for ideas.
Andy
Old 5th February 2012, 12:33 AM   #2
GloBug is offline GloBug  Canada
Banned
*Not an expert*
Sounds like you have ADD.
I would build something with the LM3886s and the caps.
You could sell the extra boards, regulators, LM4780, opamps and chokes etc. (I myself would keep at least the LM4780 for a rainy day)
I can't really recommend a specific design for you, as I have not heard many of them
Just build something, they make a nice amplifier.
At the moment I have the Audiosector LM3875 on breadboard. I have added proper capacitance, dual 25v transformers. I really enjoy it.
Old 5th February 2012, 02:03 AM   #3
Thanks for your input Globug!
I don't feel I'm quite at the ADD stage yet, but you know what it's like when new designs come out and you're young (i'm not so young anymore).
The LM3886 is a good place to start I agree. I think I should sell the 4 x LM4780+boards, god knows how I accumulated 4 of them!
That still leaves the design, we have enough components for non/regulated psu with inverted/non inverted amp with enough to do a buffer...
Thanks!
Andy
Old 7th February 2012, 05:07 PM   #4
You mean, you don't remember what you bought all those components for?
With 10 channels of amplification you could build five active 2-way speakers for a home theatre. You could also build a pair of 3- or 4-way active speakers, and use the left-over amps to bridge or parallel them for the ways that need more power. Then there is the possibility to make a stereo amp for each room in your house. Or you could simply build one variant of each non-inverted, inverted, regulated supply, unregulated supply, with and without all optional components, you name it. Then make a nice and thorough listening comparison and post the results.
Selling what you don't need is of course an option, too, but a pity.
If you've always done it like that, then it's probably wrong. (Henry Ford)
Expert advice on what preamp to chose CENTRAL Tubes / Valves 25 30th December 2011 11:30 AM
Requesting expert advice. jasongalambos Car Audio 2 16th August 2011 03:31 AM
I need some eq. hook up expert advice please! graykeene Tubes / Valves 0 11th July 2007 08:44 PM
Granddaddy System!Expert required! Alpine?Fosgate?Or Non-Brand? lynxjava Car Audio 36 10th February 2006 05:34 AM
Page generated in 0.08373 seconds (78.01% PHP - 21.99% MySQL) with 10 queries
