Old 4th February 2012, 12:38 AM   #1
Default Input impedance of inverting stage of TPA6120?
I would like to find out TPA6120 built in the datasheet reference schematic "Single-Ended Input With a Noninverting Gain of -1 V/V" with Rl = 1k and Rf = 1k.
It says the input resistance of TPA6120 is 300k, however, I am a bit confused because input resistance and input impedance are clearly different concepts. So I figured this should not be the input impedance of this chip.
Also, in my past experience, I figure the input impedance of this stage is quite low.
Has anyone measured this or know an equation to come up with this?
Old 4th February 2012, 01:21 AM   #2
nigelwright7557's Avatar
If the audio goes in on the + input then the input impedance is 300K.
If the audio goes in on the - input it will be the input resistor to the - input.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 4th February 2012, 02:04 AM   #3
Thank you very much, Nigel!
Old 4th February 2012, 11:03 AM   #4
Using the 1k & 1k around the inverting amp, you will probably need a source impedance <=51r.
Aiming for ~10r might be better.
regards Andrew T.
Old 4th February 2012, 12:14 PM   #5
Mooly's Avatar
The data sheet says it's a current feedback (CFA) type opamp so that is one reason why the resistor values are low. You need to keep to that and use a suitable driver before this device.
The inverting and non inverting input impedances are very very different on a CFA amp as far as I know. Non inverting input is normally high impedance and inverting is low impedance.
Looks a very interesting device though
A simulation free zone. Design it, build it, test it.
Old 4th February 2012, 01:44 PM   #6
gfiandy is offline gfiandy  United Kingdom
Audio Engineer
gfiandy's Avatar
If you haven't used current feedback amplifiers before, be sure to take notice of the feedback resistor value requirements. If you have reasonable math and some electronics this is a good description. You can treat the positive input much like you would a voltage amplifier. The negative input needs the correct resistance feedback resistor to remain stable and you must ensure parasitic capacitance is minimised. So it it's on a plane you may need a guard ring to isolate the input from the plane capacitance or to relive the plane in that region.
http://cas.ee.ic.ac.uk/people/dario/...cf-sloa080.pdf
Andy
non inverting op amp input impedance help sirus the virus Solid State 5 8th December 2010 06:11 PM
How to design input stage with specific input impedance/pot value mahleriana Tubes / Valves 0 16th November 2009 09:37 PM
Class D input LM311 Inverting input zox2003 Class D 1 1st February 2008 07:48 AM
TPA6120 without input buffer mr.duck Chip Amps 11 12th January 2007 10:46 AM
Input impedance of a non-inverting op amp? glennb Chip Amps 24 21st May 2004 03:24 AM
Page generated in 0.08090 seconds (75.38% PHP - 24.62% MySQL) with 10 queries
