Old 3rd February 2012, 10:58 PM   #1
happy hippy's Avatar
Default Preamp
Hello there,
Here's the schematic for my new preamp. It will feed an LM3876 amp. According to TI, I can substitute an OPA2132 for the TL072 if I choose to. I'll be breadboarding it an then we'll see what it sound like. All comments, constructive criticisms, etc. are gratefully appreciated, as I'm an amateur at this. Everything on here has bee copied off several sites, so I don't think there will be problems. You can see the power supply on the LM3876 PowerSupply thread I posted in the appropriate sub-forum.
Thanx
The Happy Hippy
When all else fails, read the instructions.
Old 3rd February 2012, 11:00 PM   #2
Default OOps
Here's the schematic.
Old 3rd February 2012, 11:23 PM   #3
nigelwright7557's Avatar
Your pin numbers 2 and 3 are marked the wrong way around.
You have 3- and 2+ when it should be 3+ and 2-.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 4th February 2012, 12:24 AM   #4
The gain pot looks a little odd, too.
Speaking of which, consider moving that behind the tone control, which will no doubt be relatively noisy. (No need to spoil the LM's good noise performance.) A 10k type will do fine then, it should be low enough to be usable in the amp input and not too low for the modest load driving capabilities of a 072.
Old 4th February 2012, 01:15 AM   #5
Default Pots
You haven't seen the amp schematic yet, 'cause I don't have it up on this thread yet. But there is a 10k pot between the preamp and the amp. It may look odd, but then, so do I All the downloads I did of similar units had both, so that's the way I drew it. Being a novice, I don't really know why both of these are there. So if you can enlighten me it will be appreciated.
Thanx
The Happy Hippy
Old 4th February 2012, 11:00 AM   #6
Go to ESP and Decibel Dungeon and do some reading.
regards Andrew T.
Old 4th February 2012, 01:19 PM   #7
...seconded:
100W Guitar Amplifier (Mk II)
Old 4th February 2012, 05:21 PM   #8
Puffin is offline Puffin  United Kingdom
Thirded
Old 4th February 2012, 07:09 PM   #9
Why?
Old 4th February 2012, 08:05 PM   #10
Originally Posted by happy hippy View Post
Why?
Yuor gain pot doesn't do anything than short the input at its top setting.
your input impedance is far too low for a passive bass guitar and you
will lose all the top end etc .....
Its very wrong and very uninspiring. You'd be far better off finding a
decent bass pre-amp schematic or copying the pre-amp section
from the service manual of a good bass amplifier.
The fact you asking Why ? is why you need to do a lot more learning.
I wouldn't use a chip-amp for anything other than a practice amplifier.
TBH if you like good sound don't even think about building a bass amplifier.
I can design hifi circuits but wouldn't know where to start building
something that sounds like my Peavey MkIII, I've looked at the circuit,
its wild, wacky and not remotely hifi, but sounds to me, excellent.
Checkout the features of the combo's on this page, they have all
the basics you need to include in a flexible good cheap bass combo.
Good Cheap Bass Combo Amps - Budget Bass Combo Amp Guide
Bang for buck and feature set consider trying to
build one of these and how much it would cost :
Behringer Ultrabass BXL900A
rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
Running a tube preamp into a solid state preamp? Pckid212 Solid State 3 26th November 2009 02:45 PM
Tube Preamp Popping on Source Input Change (?) / 6DJ8 Preamp On Chip Amps MartyM Tubes / Valves 3 16th October 2008 04:52 AM
Guitar Preamp = MIC Preamp = other preamp ,,are they all same? Paswa Solid State 1 12th March 2008 05:16 PM
twisted pear Preamp/other suggestions for Preamp kit LukeDuke Chip Amps 1 1st February 2008 09:57 PM
Electret mic preamp - will phono preamp work? darthmullet Analogue Source 6 12th October 2007 07:32 AM
Page generated in 0.10702 seconds (81.51% PHP - 18.49% MySQL) with 11 queries
