| Chip Amps Amplifiers based on integrated circuits |
#11 |
Audio Engineer
OK he made some mistakes, but I don't really understand the point of in a DIY forum telling someone to go and buy a commercial product. If he wanted to do that he wouldn't have posted on DIY Forums.
Since he has said he is going to bread board this he can learn about the problems with some help. Just squashing someones enthusiasm is not "constructive criticism" and just telling someone to go and read something with no pointers to why isn't either. If you don't want to help people who post noob questions then just move on but don't ruin their enthusiasm. Having said that the rest of what sreten has said is true (as usual). If you want help on an instrument amp design you might find a more enthusiastic reception on the Instruments and Amps section. Andy |
#12 | |
I'm all for DIY when it gives you what you actually need, and you won't be disappointed. If you don't understand the problem it is highly unlikely you will build something suitable. Chip amps and basic tone controls are fine for audio, and relatively straightforward. Music instrument amplifiers are a different kettle of fish if you want a good one. They are far more complex. The above is a viewpoint to consider, buy or build, analyse it, what you'll get, make your choice. rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow |
#13 |
Ok, look at this one. Copied from
Guitar preamp tone control circuit with IC TL072 – Free Electronic Circuit Schematics Incidently, the first one was copied from Pre-Amp Equalizer Using TL074 Originals are attached. Thanx The Happy Hippy
When all else fails, read the instructions.
#14 |
Why don't you google for schematics of commercial bass guitar amps to get a feeling for the gains and input impedances that are typical? It is also recommendable to determine a frequency for the treble control, where your electric bass guitar still produces sound.
If you've always done it like that, then it's probably wrong. (Henry Ford) |
#15 |
Audio Engineer
Hi the pre-amplifier stages you have found are not really suitable for guitars. This site has a solid state preamp and power amplifier for a guitar and a good description of the reasons for the design choices.
You could use a chip amp to replace the amplifier design although my experience of chip amplifiers is they have poor saturation characteristics so if you are expecting to use overdrive in the power amplifier for a rock effect it is likely to sound nasty. By looking at it it appears that the pre-amplifier has an overdrive type circuit in it (the diodes in the second stage) but I haven't read it in full or evaluated the circuit. http://sound.westhost.com/project27.htm Regards, Andrew Last edited by gfiandy; 8th February 2012 at 03:43 PM. |
#16 | |
....also see post 7! ![]() In general Rod (ESP) has very solid designs. |
| Running a tube preamp into a solid state preamp? | Pckid212 | Solid State | 3 | 26th November 2009 02:45 PM |
| Tube Preamp Popping on Source Input Change (?) / 6DJ8 Preamp On Chip Amps | MartyM | Tubes / Valves | 3 | 16th October 2008 04:52 AM |
| Guitar Preamp = MIC Preamp = other preamp ,,are they all same? | Paswa | Solid State | 1 | 12th March 2008 05:16 PM |
| twisted pear Preamp/other suggestions for Preamp kit | LukeDuke | Chip Amps | 1 | 1st February 2008 09:57 PM |
| Electret mic preamp - will phono preamp work? | darthmullet | Analogue Source | 6 | 12th October 2007 07:32 AM |
| Page generated in 0.09543 seconds (80.35% PHP - 19.65% MySQL) with 11 queries |
