Old 25th January 2012, 09:34 AM   #1
1976 is offline 1976  India
1976's Avatar
Default PRE AMP FOR LM3886T
CAN ANY BODY PLSHELP ME I HAVE ASSEMBLED LM3886T CIRCUIT & CONNECTED IT TO+_20 V SUPPLY & USED PRE AMP FROM PACE AMP 2040.IN WHICH TR BC549 IS USED BASS IS NOT SATISFACTORY AS AT MAX VOLUME BASS SOUND GET DISTIRBUED CAN AN BODY PROVIDE A PRE AMP SHEMATICS FOR LM3886 OUT PUT IC
Old 25th January 2012, 10:05 AM   #2
just another
wintermute's Avatar
Hi 1976 I have moved your post to chipamps as it was off topic in the thread you posted in. Please note that ALL CAPS is considered shouting in Internet forums, please use lower case
You might want to read the excellent article by Michael Mardis on Gain structure, it may give you some insight into where your problem may be. What is Gain Structure?
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 25th January 2012, 12:23 PM   #3
1976's Avatar
sorry i am new to net surfing
Old 25th January 2012, 12:59 PM   #4
KatieandDad's Avatar
You will need to be a bit more specific as to what you are trying to achieve.
Also how Hi-End you are aiming to achieve.
At the good-modest end of the spectrum a simple NE5532/4 will give you the gain that you need and not compromise the quality.
http://sound.westhost.com/project02.htm
This one from Rod Elliot is pretty good for most uses. I say this "tongue in cheek" as some guys are trying to get Rolls Royce performance out of their LM3886 amps.
Old 25th January 2012, 01:21 PM   #5
1976's Avatar
i want a 50w sound output per channel & better stereo effect with soft bass.
Old 25th January 2012, 05:30 PM   #6
±20 V give you ~19 W into 8 Ohm or ~35 W into 4 Ohm. If you want 50 W into 4 Ohm, you need ±24 V for 4 Ohm or ±32 V for 8 Ohm.
Your decription sounds as if your amp was already overdirven and clipping. A different preamplifier won't change that. You either need higher supply voltage, bigger heatsinks, a different, more powerful amplifier or different speakers that give you more bass with the available power. Or you need to learn to live with what you have and not crank it up so loud.
Soft Bass? That is something you rather achieve with the speakers than with the amp.
If you've always done it like that, then it's probably wrong. (Henry Ford)
Old 31st January 2012, 02:13 PM   #7
1976's Avatar
can any body help me with ua1458tc preamp circuit diagram
Old 31st January 2012, 02:22 PM   #8
GloBug is offline GloBug  Canada
Banned
On page 5 of the Fairchild Datasheet there is a drawing of a "high impedance, high gain inverting amplifier"
Maybe you could work from that.
Old 8th February 2012, 04:51 AM   #9
1976's Avatar
i am searching for circuit digram & pcb layout of lm3886t with output 200w per channel can any one help me
Old 8th February 2012, 05:09 AM   #10
picowallspeaker's Avatar
Hi ...200 W it's a lot !
You'll need to take well into account the thermical dissipation of each chip , if you go with the paralleled version ( search for BPA 200 or 300 ) or bridged version with that chip . I've build the enhanced Power Bridge version of the Tda 2030 A ,you can find it inside the datasheet under 'Applications' , but it gives you 100 W .
MC pre pre amp for shelter 501 MK11 cjcc67 Analogue Source 19 24th May 2010 07:17 PM
Different between LM3886T & LM3886TF ttan98 Chip Amps 13 5th August 2007 02:53 PM
"TO220 11-pins 2-rows" TraxMaker's library needed for LM3886T Polo786 Everything Else 0 27th June 2006 07:14 PM
UK Group Buy - LM3886T & 10k uF Caps richie00boy Group Buys 83 31st January 2006 10:35 PM
200w amp trouble (LM3886T) - one chip only wants to oscillate chris-man Chip Amps 12 31st May 2004 10:27 AM
Page generated in 0.09596 seconds (79.37% PHP - 20.63% MySQL) with 10 queries
