Old 23rd January 2012, 09:10 PM   #1
Default opamp matching +/- input impedance necessary for buffer?
I have read a lot of articles which emphasise the importance of matching the +/- input impedance of opamps in order to achieve low distortion.
My question is, is it necessary to match the +/- impedance for opamp buffers? An opamp buffer is one where the - input is directly connected to the output with a piece of wire, not a resistor.
I found it hard to match the impedance, DC or AC, especially AC impedance in circuits like Sallen-Key filters.
Bill
Old 23rd January 2012, 11:25 PM   #2
MINUX75 is offline MINUX75  France
hello
audio is NOT high frequence, matching input and output is not necessary.
Idealy the OUT should be O,OOOOOOOOOOO Ohm like a wire and the input should be 1 0000000000 M Ohm like plastic or dry wood.
Old 23rd January 2012, 11:34 PM   #3
jcx is offline jcx  United States
op amp inputs show nonlinear input impedance if you look closely enough
can give measureable distortion - matching impedance seen by +,- inputs can help - sugested for fet inputs particularly since filter circuit impedances may be higher and their problem is nonlinear device-substrate parasitic C
it is possible to match filter component impedance with duplicate parts but not often done
don't really need to worry unless low order, smooth distortion charateristic at <0.01% levels bother you
Old 23rd January 2012, 11:40 PM   #4
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via MSN to abraxalito Send a message via Yahoo to abraxalito Send a message via Skype™ to abraxalito
I use a series resistor in the connection between output and -ve in. Not just for distortion reduction but also for improved DC offset - so the input bias currents give rise to the same voltage at each. I put around 100pF in parallel with this resistor so the input capacitance doesn't degrade the phase margin.
I think ideas are what you want to get rid of. I don't really like songs with ideas. - Leonard Cohen
Old 24th January 2012, 12:45 AM   #5
The lower the distortion the better it is.
In my BJT input power amp, when I slightly mismatched the differential input AC impedance seen from the input and the feedback I found the sound degraded.
In my 4 way active crossover with 14 stages, the ones with matching +/- input impedance show low DC offset of 0mV - 0.2mV, while those with large impedance mismatch show as much as 6mV!
I am trying to match the impedance at DC and don't worry about it at AC because it is too difficult.
The problem I had was that I don't know how to match the impedance of a buffer, i.e. the - input connects to the output.
Old 24th January 2012, 12:48 AM   #6
Interesting. I have never seen anybody published any circuits using this method.
I quickly drew it in LTSpice and it showed the same response, at least within the audioband.
When I get home, I can post a picture.
Old 24th January 2012, 04:24 AM   #7
Is it like this?
Old 24th January 2012, 04:29 AM   #8
abraxalito's Avatar
Yep - the lower of those two arrangements was what I was thinking of. So long as its not DC coupled then both pins will see 10k. Your 22pF cap prevents an HF pole developing which would compromise stability.
Old 24th January 2012, 04:31 AM   #9
On top of the issue of differential input bias current causing DC offset, here is an extract taken from the opa2134 datasheet:
For lowest distortion with a source or feedback network
which has an impedance greater than 2kW, the impedance
seen by the positive and negative inputs in noninverting
applications should be matched. The p-channel JFETs in the
FET input stage exhibit a varying input capacitance with
applied common-mode input voltage. In inverting configurations
the input does not vary with input voltage since the
inverting input is held at virtual ground. However, in
noninverting applications the inputs do vary, and the gateto-
source voltage is not constant. The effect is increased
distortion due to the varying capacitance for unmatched
source impedances greater than 2kW.
To maintain low distortion, match unbalanced source impedance
with appropriate values in the feedback network as
shown in Figure 3. Of course, the unbalanced impedance
may be from gain-setting resistors in the feedback path. If
the parallel combination of R1 and R2 is greater than 2kW, a
matching impedance on the noninverting input should be
used. As always, resistor values should be minimized to
reduce the effects of thermal noise.
Old 24th January 2012, 04:35 AM   #10
The interesting thing is, if according to opa2134 datasheet, the buffer implementation is merely R2 = 0, which means R1 || R2 = 0, and 0 < 2k, so not matching is required.
This gave rise to my original question - do we need to match the + / - impedance of an opamp in a buffer?
Help to calculate real model opamp input AC impedance. ygg-it Chip Amps 3 6th June 2010 07:35 PM
buffer and impedance matching Professor smith Pass Labs 5 16th June 2009 09:37 PM
50M input impedance buffer? takodabut Solid State 12 5th December 2008 09:42 PM
Cathode Follower Buffer Input Impedance xcortes Tubes / Valves 5 1st December 2005 05:10 PM
Tube differential input/buffer /w opamp output gainclone aletheian Chip Amps 2 23rd August 2005 07:36 AM
Page generated in 0.10545 seconds (80.36% PHP - 19.64% MySQL) with 11 queries
