Old 25th January 2012, 09:49 AM   #21
just another
wintermute's Avatar
Hi Bill, I think I have your work email address, is that OK? I assume you are still there? last email was in sep 2006!!! you had changed jobs by the looks of it. I'll send you a PM to check The email address you have for me is no longer active.
Yes if you are using a generic opamp in LTspice then it is an ideal opamp so totally devoid of any real world characteristics, TI has a lot of models available so the OPA627 should be on their site I suspect. The file I send you should help with working out how to do that I suspect I've been through the same, started off with what ever was available, and just did ac analysis, then moved on to getting models for the parts I have and doing transient analysis. It's a powerful tool provided you recognise it has limitations and is a bit too perfect
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 25th January 2012, 10:18 AM   #22
Thanks, Tony. You can send me email via this site. My old email was long gone.
Unfortunately, TI has only TI part models from my memory. I have never seen the opa627 model.
Old 25th January 2012, 10:33 AM   #23
just another
wintermute's Avatar
TI bought Burr Brown a while back so have all of the BB stuff. Precision Amplifier - Low Offset Voltage - OPA627 - TI.com scroll down to the bottom and go to the pspice link.
I'll send you an email but you'll have to reply before I can send the attachment because you can't send attachments though the forum email system
Tony.
Some of my photos
Old 25th January 2012, 01:57 PM   #24
jcx is offline jcx  United States
Spice op amp macromodels seldom use good input Q models - often no nonlinear junction C at all so they do not give good indications of the cm input nonlinearity distortion
http://www.sg-acoustics.ch/analogue_...distortion.pdf has measurements - the OPA627 is unusually good with its Difet input Q
you can get around the problem by "cascoding" the whole input op amp by bootstrapping power supply pins at considerable circuit complexity
Supply Bootstrapping Reduces Distortion In Op-Amp Circuits | New operational amplifiers optimized for high-performance audio and ultrasound applications combine extremely low total harmonic distortion plus noise (THD+N), -130 dB, with large output vo
Old 25th January 2012, 08:39 PM   #25
Perhaps you could use an ideal high-gain controlled voltage source combined with two big junction diodes as the op-amp model, one big junction diode from the positive input to the negative supply and an equally big junction diode from the negative input to the negative supply. Choose the junction diodes to have a capacitance of a few pF. It won't match the real op-amp very well, but the trends will be the same.
Old 25th January 2012, 10:33 PM   #26
just another
wintermute's Avatar
This model may be better than most...
extract from the E version of the model:
* DIFF INPUT CAPACITANCE
CDIF 1 2 8.0E-12
* COMMON MODE INPUT CAPACITANCE
C1CM 1 99 7.0E-12
C2CM 2 99 7.0E-12
* INPUT VOLTAGE NOISE
VN1 61 0 0.6
VN2 0 62 0.6
DN1 61 63 DY
DN2 63 62 DY
EN 64 1 63 0 1
* INPUT CURRENT NOISE
RN1 0 65 60.3865
RN2 65 66 60.3865
RN3 66 0 120.773
RN4 0 67 60.3865
RN5 67 68 60.3865
RN6 68 0 120.773
Tony.
Some of my photos
Old 26th January 2012, 01:10 AM   #27
those are linear C unless there is a model statement or a poly def - won't show nonlinear effects
Old 26th January 2012, 01:46 AM   #28
just another
wintermute's Avatar
OK thanks jcx,my knowledge of the elements of a model is limited, but I could see that it had much more than the usual models I've seen in the past
Tony.
Some of my photos
Old 14th February 2012, 07:19 PM   #29
I have just done another active line level crossover network again. The result to me is very obvious. The DC offset of the opa627 increases along with the difference increase of the +/- input impedance. However, when it is used in a buffer, i.e. a piece of wire goes from the -input to the output, the DC offset remains low, even though the +/-input impedance is not matched.
Can somebody give an explanation?
Old 14th February 2012, 08:00 PM   #30
keantoken's Avatar
If the amp has a gain of 10, the DC offset will be multiplied by that. So if a opamp with a gain of 10 has a 6mV offset, if it is then configured for unity gain it will have an offset of .6mV.
PS. The OPA637 model is much more detailed... Here is a copy I modified to have the GBP of the OPA627 (but I may have messed something else up in doing so):
.SUBCKT OPA627_k 1 2 3 4 5
C1 11 12 2.5E-12
C2 6 7 16.75E-12
DC 5 53 DX
DE 54 5 DX
DLP 90 91 DX
DLN 92 90 DX
DP 4 3 DX
EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5
FB 7 99 POLY(5) VB VC VE VLP VLN 0 552.6E6 -60E6 60E6 60E6 -60E6
GA 6 0 11 12 1.810E-3
GCM 0 6 10 99 2.868E-9
ISS 3 10 DC 486.0E-6
HLIM 90 0 VLIM 1K
J1 11 2 10 JX
J2 12 64 10 JX
G11 2 4 POLY(4) (10,2) (11,2) (4,2) (66,0) 0 1E-12 1E-12 1E-12 1.6E-6
G21 1 4 POLY(4) (10,1) (12,1) (4,1) (68,0) 0 1E-12 1E-12 1E-12 1.6E-6
R2 6 9 100.0E3
RD1 4 11 552.6
RD2 4 12 552.6
RO1 8 5 54
RO2 7 99 1
* RP 3 4 4.286E3
RSS 10 99 411.5E3
VB 9 0 DC 0
VC 3 53 DC 2.700
VE 54 4 DC 2.700
VLIM 7 8 DC 0
VLP 91 0 DC 55
VLN 0 92 DC 55
* OUTPUT SUPPLY MIRROR
FQ3 0 20 POLY(1) VLIM 0 1
DQ1 20 21 DX
DQ2 22 20 DX
VQ1 21 0 0
VQ2 22 0 0
FQ1 3 0 POLY(1) VQ1 5.38E-3 1
FQ2 0 4 POLY(1) VQ2 5.38E-3 -1
* QUIESCIENT CURRENT
RQ 3 4 7.5E4
CDIF 1 2 8.0E-12
C1CM 1 99 7.0E-12
C2CM 2 99 7.0E-12
VN1 61 0 0.6
VN2 0 62 0.6
DN1 61 63 DY
DN2 63 62 DY
EN 64 1 63 0 1
RN1 0 65 60.3865
RN2 65 66 60.3865
RN3 66 0 120.773
RN4 0 67 60.3865
RN5 67 68 60.3865
RN6 68 0 120.773
.MODEL DY D(IS=1E-15 AF=1 KF=73.4E-18)
.MODEL DX D(IS=800.0E-18)
.MODEL JX PJF(IS=500.0E-15 BETA=3.37E-3 VTO=-1)
.ENDS
Unfortunately it seems nonlinear input capacitance is still not modeled. However if you look at the datasheet the inputs are cascoded so the input capacitance should be linear...
- keantoken
Help to calculate real model opamp input AC impedance. ygg-it Chip Amps 3 6th June 2010 07:35 PM
buffer and impedance matching Professor smith Pass Labs 5 16th June 2009 09:37 PM
50M input impedance buffer? takodabut Solid State 12 5th December 2008 09:42 PM
Cathode Follower Buffer Input Impedance xcortes Tubes / Valves 5 1st December 2005 05:10 PM
Tube differential input/buffer /w opamp output gainclone aletheian Chip Amps 2 23rd August 2005 07:36 AM
Page generated in 0.12372 seconds (82.69% PHP - 17.31% MySQL) with 11 queries
