Old 22nd January 2012, 11:22 AM   #1
pra3718 is offline pra3718  India
Default Linkwitz pluto almost done.
Thank you Siegfried Linkwitz for publishing pluto. I have tried my level best to copy as possible as to SL's pluto but lacking of parts and my knowledge I could not. Yet, my build sounds pretty good.
I used op-amp NE5532, well fabricated board and good quality capacitors. Instead of using LM3886 I used TDA7265 mono for tweeter and bridge for woofer.
5.5" woofer and 2" tweeter produced very clean sound at low-medium volume level. As I found pluto does not sound good at high volume level. Classical & Jazz tracks sounds very good. Tweeter really sings all the tracks but not the woofer (I can't explain more about woofer or may be reason I have skipped some parts original to pluto.)
Over-all the electronics is very good. I like it. thank you SL.
Old 22nd January 2012, 01:16 PM   #2
Speedskater's Avatar
With the Pluto enclosure being built out of US sized plumbing parts from a US hardware store it is a struggle in other parts of the world finding equivalent sized parts at reasonable prices.
Kevin
Old 22nd January 2012, 01:43 PM   #3
That's true, that's why my electronics is poor to SL's pluto.
Old 22nd January 2012, 01:55 PM   #4
The other problem many DIY builder have been having is find components (mostly capacitors) of the correct physical size and value to fit the spacing of the older pc boards.
Kevin
Old 23rd January 2012, 01:02 PM   #5
Not only capacitors I faced problem with resistors also, 6.8K was available but not 3.4K to my supplier so I used 3.3K.
Old 31st January 2012, 05:58 AM   #6
gainphile's Avatar
Hello ... Got your PM but my mailbox is full!
http://gainphile.blogspot.com
Old 31st January 2012, 10:48 AM   #7
@gainphile, please comment to schematic post # 3, should I try to build original ?
Old 3rd February 2012, 12:54 AM   #8
BrianL is offline BrianL  United States
There is not a parts availability problem. Digi-key and Mouser will ship to most any place in the world, I believe. There is a new Pluto PCB with easier-to-obtain capacitors. Resistors should not be difficult. The best approach by far is to order the PCBs from linkwitzlab.
bel
Old 3rd February 2012, 08:35 AM   #9
Thank you BrianL
After reading lot-off pluto, now this is very sure not only exact build of electronics, speaker are similarly important. Madisound's speaker quotation (Driver+Shipping) is expensive for me. Without AURA NSW2-326-8A , Seas L16RN-SL, I cant' build SL's pluto.
Old 3rd February 2012, 04:16 PM   #10
kuldeepsingh's Avatar
Send a message via MSN to kuldeepsingh Send a message via Skype™ to kuldeepsingh
ya, getting good speakers in India is still a fight.
My Best LM3886 PCB layout
Linkwitz Pluto + MiniDSP + ClassD greenm01 Multi-Way 18 20th January 2012 10:27 PM
Linkwitz Pluto-alternated driver choice soundnovice Multi-Way 21 2nd November 2011 02:48 PM
FS: Major Caps Upgrade for Linkwitz Pluto Loudspeakers cuibono Swap Meet 6 7th May 2011 12:48 AM
alpair/jordan fullrange vs pluto linkwitz fxs Full Range 26 21st February 2011 08:07 PM
FS:Linkwitz Pluto Nikola Krivorov Swap Meet 0 2nd October 2009 08:44 AM
Page generated in 0.11652 seconds (81.06% PHP - 18.94% MySQL) with 11 queries
