| Chip Amps Amplifiers based on integrated circuits |
Hi There,
By popular demand ( of at least 2 people) here is the proposed schematic of my new amp. (See LM317 post in power supply forum.) An comments, critizisms, changes, etc., are appreciated, as I don't really know wht I'm doing. I just take ideas and parts of schematics, and put them together, and this is what hppened. Thanx The Happy Hippy
When all else fails, read the instructions.
#2 |
I can't understand why you are so reluctant to download the National Application Notes for this series of chipamps and the datasheet for this device and simply follow the National guidance.
regards Andrew T. |
#3 |
I agree wholeheartedly... But he's awfully close, and all the important bits are as the App Notes.
Pass Labs Pearl Phono -- Pass B1 Preamp -- Pass F5 amplifier -- Pass Labs Pearl 2 |
#4 | |
#5 |
then delay your "design efforts" and buy a kit of bits and assemble it exactly as the builder instructs.
Note this automatically excludes all kits that don't have a comprehensive set of assembly/build instructions. When you can understand what the A.N. & Datasheet are telling you, then you can recommence your design project.
regards Andrew T. |
#6 |
Andrew, if you build a chipamp with the schematic right from the app notes, what's the big deal? There is enough information out on the web, many different tutorials, photos, build logs, and different variations on the theme that a reasonably smart individual, who is being careful, can build one from a schematic.
He doesn't need to buy a kit. There is no argument that it might increase the probability of success, but it is not a requirement.
#7 | |
#8 |
Here's the whole thing put together. Any comments, criticisms, etc., will be appreciated. In your opinion, will it work?
#9 |
You have succeeded in designing a 10W bass guitar amp... Ten. Watts.
Are you sure you want to use 15v rails? (Hint hint)
#10 |
I have been told that the chip, LM3876, will put out 56 watts. And the voltage runs from 20v to 70v without much distortion. Also, that the wattage will be there anyplace in that range. So I guess I don't understand the 10 watts. If I have 30 volts across the rails, and over 3 amps available, why 10 watts?
Thanx Paul J.
| Problem with LM3876 | Alexus | Chip Amps | 11 | 18th March 2011 10:00 PM |
| LM3876 for guitar? | Wynand | Chip Amps | 4 | 2nd November 2005 08:26 AM |
| LM3876 vs. LM3875 | Wynand | Chip Amps | 3 | 12th July 2005 09:03 PM |
| Lm3876 | bobossa | Chip Amps | 1 | 1st March 2005 04:18 PM |
| hi - LM3876 problems... | RichardA | Chip Amps | 7 | 14th September 2004 04:32 PM |
| Page generated in 0.10141 seconds (79.87% PHP - 20.13% MySQL) with 11 queries |
