diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Chip Amps (http://www.diyaudio.com/forums/chip-amps/)
-   -   help choosing amplifier design/kit (http://www.diyaudio.com/forums/chip-amps/204774-help-choosing-amplifier-design-kit.html)
gafhenderson 18th January 2012 01:21 PM
hi,
i wish to make a new amplifier as my old one died and tbh its very old and not worth trying to fix. i have an old media PC case i will be using to house the parts.
what i want.
1) 2x 50-100watts into 8ohms.
2) possibly a subwoofer channel? - not sure what kind of power would be available.
3) most bang per buck.
i am looking to put this together using mostly pre-built components. i could be convinced to go all out into the manufacturing process if it represented large gains in output+fidelity for the money compared to the extra effort required.
the sound input will be directly from a PC sound card so apparently no volume control is required, however if a subwoofer channel is possible, then one would be required for the sub channel.
not really sure what the specific question would be, just looking to get a discussion of possible options.
thanks for your help.
gafhenderson 19th January 2012 01:43 PM
i found this site
Tripath TK2050 Amplifier
which seems fairly straight forward if not very elegant. is it correct tho?
eBay - The UK's Online Marketplace
2 Channel 100w TK2050 TP2050 Tripath Class-T Power Amplifier Audio Board
i have looked on the forums and they seem to have good feedback.
can they be run bridged to get 100watt into 8ohms?
GloBug 19th January 2012 02:30 PM
You could try a kit(s) from DIY Chip Amplifier Kits, PCB's, Components and Information.
Even better then a subwoofer amp IMO is to Bi-Amp.
Use one kit for the Highs and one for the Lows.
You will have to split the signal before the amps.
Some say bass is Mono, the rest of us like bass in stereo. Bass sometimes sounds funny when summed into mono. Stereo sounds better for movies etc, and yes I can hear a difference between mono and stereo bass.
Also when you Bi-Amp, you get much more power. It takes much more energy to produce bass with the high frequencies riding along and vice-versa. So by separating the frequencies the amps can put all their power into their particular frequency range. You could say it your power would ~double. ;)
Something to think about anyways.
gafhenderson 19th January 2012 02:50 PM
thanks for the reply but most of that went over my head, please pardon my ignorance.
i think i understand what you're saying about the bi-amp as this sound like what i had initially thought out in my head (correct or not).
http://img703.imageshack.us/img703/3298/ideam.jpg
GloBug 19th January 2012 03:14 PM
Yes you have the right idea.
The main difference is that BiAmping is in Stereo, as opposed to processing the bass into mono.
Copyright 1999-2017 diyAudio
