| Chip Amps Amplifiers based on integrated circuits |
#31 |
You buy such a 'chip', connect a source to the input, a speaker to the output and a power supply to the supply connector. What exactly is the 'building' part of it?
If you've always done it like that, then it's probably wrong. (Henry Ford) |
#32 |
These sort of devices allow you to throw an audio output on any portable media device, in fact there development has been led by that markets requirements. Not the final word in hi fidelity, but had some reasonable results driving decent headphones (quite surprising), but for limited bandwith MP3 playback over a phone speaker, perfect, takes up little board space, not a lot of heatgenerated, minimal power wasted (perfecr for battery use) and easily to implement.
I think the next step will be a class D amp packaged like Nationals simple switcher convertors: http://www.ti.com/lit/ds/symlink/lmz14203.pdf You can build a mini system with IP Op and PSU using very few devices these days and very little board space. |
#33 |
Thanks for your comments. I liked the smart a** funny comments as well. I think it is about time that we have some low-power all-in-one amp chip.
#34 | |
#35 | |
This is down to the fact that it is very difficult to build large capacitors out of thin silicon. It's easier to build them out of alluminium and plastic. Even the ILP Hybrid amps that I suggested in the early part of this thread are Hybrids. The lowest powered amps of all - Hearing Aids - are still, to my knowledge, Thick Film construction. |
#36 |
Banned
I don't know if I would want things to get any smaller from a DIY point of view.
I still like how capacitors were treated as a component and proudly stood atop of classic tube amps. |
#37 |
Its easy to make silicon transistors.
Resistors are just thin tracks or lumps of silicon. Inductors are just coils of silicon or copper traces. Capacitors though need larges areas of conductive film. It's just not economical to make large caps on a semiconductor die. |
#38 |
I don't understand why you need to bring personal comments into a technical Forum.
I am reporting your post.
regards Andrew T. |
#39 |
Attacking ideas is fine, avoid comments that might be construed as a personal attack.
www.kta-hifi.net |
#40 |
Yes they will be hybrids, lots of devices are these days, even BGA devices such as FPGA's. PAckaging is also smarter these days so a lot dont look like the hybrids of old, with a big black lump of goo on them, also multi chip modules are starting to aspear. So before long you might find a multichip module with DSP,FPGA, DAC etc on 1 BGA device and a module for outputs.
An example of how some of the new hybrids look, you just treat them as a single SMD device. QPI-9LZ |
| Mounting an External Amplifier power supply?? | MurphyUHF10 | Power Supplies | 10 | 1st December 2010 02:18 PM |
| 6 Volt Sony Power Amplifier | WSJ | Car Audio | 1 | 12th June 2009 08:09 AM |
| 6 Volt Sony Power Amplifier | WSJ | Vendor's Bazaar | 0 | 8th June 2009 02:11 PM |
| External passive crossovers... In front of the power amplifier? | luvdunhill | Multi-Way | 8 | 27th July 2007 12:58 AM |
| Inductors before the power pins vs ground bounce | patwen | Digital Source | 4 | 4th November 2002 07:34 PM |
| Page generated in 0.10715 seconds (79.49% PHP - 20.51% MySQL) with 11 queries |
