| Chip Amps Amplifiers based on integrated circuits |
#41 |
Are you suggesting there are a pair of these inside every Iphone?
regards Andrew T. |
#42 | |
However I was referring to bulk capacitance on the power rails on the amp PCB, having the chip on a breadboard with no oscillations is not evidence it meets specifications at the power level you used nor higher power. Higher output requires more capacitance. You might choose to integrate the power supply circuit onto the amp PCB to serve as this capacitance yet that is another example of why not to put it in the chip, to keep cost down and controlled by the amp designer. Last edited by !; 17th January 2012 at 07:16 PM. |
#43 |
All I am saying is when I connect my iPhone headphone's output to my 400 watts flat response monitors/speakers without using any amplifier, they sound great. I read somewhere that iPhone has a built-in class D amplifier that delivers up to 1.5 watts of audio per channel. It even senses whether I have headphones or external speakers attached and automatically changes the output from 400 mw to 1.5 watts based on the impedance of the speakers and the length and connection bands of the male connector. Very smart.
Back to my L 4780 project. |
#44 |
No, just a suggesting a big "chip" that only needs power to operate.
The 4GS seems to use a Cirrus Logic chip, according to the reviews it does a good job in there. |
#45 | |
10V signal output into 32 ohm headphones = 0.31A = 310mW 10V signal output into 8 ohm speakers = 1.25A = 1.25W Last edited by !; 17th January 2012 at 07:58 PM. |
| Zaph zrt advices: components and building doubts | francorovereto | Multi-Way | 28 | 18th November 2010 05:52 PM |
| LM3886 minimal vs. additional components | kgb_m3 | Chip Amps | 22 | 22nd January 2010 03:50 PM |
| Building minimal PSU for LM1875 gainclone | Pato666 | Power Supplies | 0 | 19th November 2009 02:03 AM |
| building speakers with components with different impedances | ubernova | Multi-Way | 10 | 27th December 2008 09:14 PM |
| Minimal AMP named C-TEC | Stee | Solid State | 0 | 19th April 2007 08:44 PM |
| Page generated in 0.08553 seconds (75.07% PHP - 24.93% MySQL) with 11 queries |
