| Chip Amps Amplifiers based on integrated circuits |
Hi everyone,
I'm building another gainclone using the basic PS for lm3886s on the chipamp website, I believe based on Carlosfm's design but without regulation. I'm using this dual mono amp to power the tweeters in a small active eqed MTM pair and I'm waiting for the MUR860s to arrive. In the mean time I used MUR160s to test the PS on the breadboard and cooked them. (They are rated for 1A, 600V reverse voltage,) I'm using two dual secondary 21V transformers, 120VA each. Each is fused with a 1A slowblow fuse. I'd like to have my understanding checked and corrected if possible, I'm assuming that the 1 Ohm resistor across the rail after the 4,700uF cap allows for nearly full current to pass and once I present the PS with the amp, the current will lower. Is this correct? I don't want to hook up the MUR860s and cook them too, (although this would sadly suit my idiom...) How much current will these chips typically pass during idle, regular use, and at peak moments? Thanks for any quick comments gary Last edited by gary h; 12th January 2012 at 04:34 PM. |
#2 |
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
Try less expensive devices, UF5408 by example.
A veces pongo un circo y me crecen los enanos... "Que se llama soledad", Joaquin Sabina, el capo. |
#3 |
With no load even 1 A diodes should be sufficient. You have either connected the diodes wrong or there is a short in your power supply.
The 1 Ohm resistor is in series with a 100 nF capacitor. Only very little current is needed to charge that cap. That is not the issue, except of course, if you forgot that capacitor. That would be a nice amp that reduces the current in a power supply when you connect it. The current through the diodes will of course be higher, when the amp is connected, but the current through that 1 Ohm resistor will remain the same. The idle current of the LM3886 is given with 50 mA typ, 85 mA max. The typical peak current is 11,5 A, although the Overture Design Guide peaks out at 8 A. Typical listening levels are below 1 W average, which means 500 mA or less. Even your 1 A diodes should cope with that as long as you don't crank the amp up. Use ready-made rectifier bridges to avoid wiring mistakes. Use The Dim-bulb Radio Tester, when you test the power supply.
If you've always done it like that, then it's probably wrong. (Henry Ford) |
#4 |
Thanks Pacificblue.
| Quick F5 PS question | DJNUBZ | Pass Labs | 7 | 3rd August 2011 10:39 AM |
| Novice PS Question: Diode Dilemma | slor | Tubes / Valves | 8 | 14th April 2008 04:05 PM |
| Old radio quick question re PS | Simpleton | Tubes / Valves | 17 | 25th August 2006 04:25 PM |
| Diode protection: Quick Question | 2sb18 | Chip Amps | 4 | 2nd March 2006 07:44 PM |
| Quick Aleph2 PS question/opinion | vinay | Pass Labs | 2 | 10th February 2003 04:16 AM |
| Page generated in 0.07105 seconds (75.99% PHP - 24.01% MySQL) with 10 queries |
