Different case materials=different sound...ummm...explain.
Old 18th September 2003, 06:06 AM   #1
Doovieman is offline Doovieman  United States
Default Different case materials=different sound...ummm...explain.
I've been reading a lot of these threads where people make really beautiful amps. I'm quite impressed by the workmanship and thought that goes into these boxes, but what I don't understand is why you think that a chassis made of brush wood from Africa that is dried for 15 years will cause the amp to sound better/worse than an amp with a plain aluminum box. As an engineering student, I must say that none of that makes sense. If you were building a speaker, fine...but an amp? I'm going to guess that most of you who believe in this stuff will jump on this thread and say, "try it first then knock it." I'm not trying to insult anyone, but coming from an engineering background, this doesn't make sense to me. Anyone care to share a quantitative explanation? Thanks a lot,
Doovieman
Old 18th September 2003, 06:11 AM   #2
cowanrg is offline cowanrg  United States
cowanrg's Avatar
Send a message via AIM to cowanrg
every time i build and amp or have something open while playing, i tap on the caps, case, etc, and generally rattle the thing around a little bit.
i sleep better knowing i cant hear a bit of difference while doing that...
Old 18th September 2003, 06:26 AM   #3
jcarr is offline jcarr  United States
Certainly the conductivity of the casing/chassis has an effect in phono cartridges (although I reckon that the effect in cartridges is more significant than in power amplifiers).
Surf to Google and type in
induced current lenz effect
or
induced current lenz law
hth, jonathan carr
http://www.lyraconnoisseur.com/, http://www.lyraaudio.com
Old 18th September 2003, 06:42 AM   #4
Turntables/tube amps is one story. I want to know about semiconductor amplifiers. I don't beleive that the lenz effect has anything to do with a semiconductor. Thanks for the info though.
Doovieman
Old 18th September 2003, 07:41 AM   #5
mozikluv is offline mozikluv  Philippines
Send a message via Yahoo to mozikluv
Default wooden case or aluminun case for amp
i am in consonance with dovieman that putting an amp in a wooden casing or aluminun casing would make a difference in audio sound. but am willing to try this style, i have a class A amp 20w per channel which i have build and am very much satisfied with its performance and its cased in aluminun. will let you know guys of the result. i know how this amp sound in my music room.
"none but the brave deserves the fair" shakespeare
Old 18th September 2003, 07:56 AM   #6
Steve Eddy is offline Steve Eddy  United States
Steve Eddy's Avatar
Default Re: wooden case or aluminun case for amp
Hey, even if it doesn't have any effect at all, it LOOKS DAMN GOOD!
se
Old 18th September 2003, 08:14 AM   #7
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
Why don't you just try different platforms under SS amps and listen to their effect? All components are bloody microphonic one way or another. If you can hear difference between caps and wire you posess ears with sufficient resolution to distinguish between different construction materials. If not - The engineering explanations might not be very convincing, but so what?
Old 18th September 2003, 10:27 AM   #8
Colin is offline Colin  United Kingdom
If we're talking about purely microphonic effects, it probably depends on how loud you play and how close to the speakers the amplifier sits, how it's coupled to the floor (via any shelves or supports), how well the components are mounted inside the case. Does it make more of a difference with the Gainclone because the components are usually hard wired and may be more prone to structural vibration than pcb-mounted components?
It's interesting that so many systems seem to sit between the speakers. Apart from any vibration effects, in my experience, anything between the speakers tends to detract from the imaging to some extent.
Colin
Old 18th September 2003, 12:03 PM   #9
AudioFreak is offline AudioFreak  Australia
Warp Engineer
On Holiday
AudioFreak's Avatar
Of course, if you use a case made of non conductive material the RFI / EMI shielding will be severely effected.
- Dan
Old 18th September 2003, 12:14 PM   #10
analog_sa's Avatar
I haven't found room positioning with respect to speakers to have any meaningful effect. Structural vibration seems more important than air-borne. Also a lot of components actually produce vibrations when passing signal. I am also suspicious about the importance of RF shielding - some of the best sounds i've heard originate from amps with no amount of screening whatsoever, but admittedly they are all valve designs.
Different case materials=different sound...ummm...explain.Hide this!Advertise here!
Can someone explain the theory behind "sound reinforcement drivers"? Cal Weldon PA Systems 30 19th December 2007 12:18 AM
Ummm Hey! RogueThunder Introductions 1 13th February 2006 04:35 PM
Did you know that the tightness of the jacket materials could change the sound? commstech Parts 26 14th November 2004 11:36 AM
Ummm..Protection? CryingDragon Solid State 8 13th September 2002 08:05 PM
Copyright ©1999-2017 diyAudio
