| Chip Amps Amplifiers based on integrated circuits |
Hi everyone,
I just finish my TDA2050 30W/channel amp and it works very well. Now I am just about to add a UPC1237 chip for speaker protection and here is my problem. The datasheet of the UPC1237 sais that the overload detection fonction is not avalaible (on pin 1) Can anybody help me with this. Is there a external circuit that I could connect to this chip in order to give my amp an overload detection fonction? Thanks |
#2 |
That's a great question. I've searched far and wide, but no avail.
I'm sure someone on the forum will be able to help us.
#3 |
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#4 |
The link is about SOA??????
#5 |
Yes.
#6 |
There is a clip detector circuit on the leach amp site. Knowing the IC functionality, u can use this ckt, IMO, but not sure.
Gajanan Phadte |
#7 | |
Pin one is a switching input that will switch off the relay when it is taken high. It's up to you to design a circuit that will make pin 1 high when there is an overload condition. BTW Clipping is not understood as overload in the context of these kind of circuits - clipping is simply defined as 'clipping' ![]() jan didden
/Another new issue: Linear Audio Volume 3! |
#8 |
Overload protection needs speaker/ic current detection. You have to include a resistor(of small value) either in series with the speaker or the power rails, one on each rail and detect the drop across each. Then use a comparator or opamp circuit.
Gajanan Phadte |
#9 |
thank janneman,
Now what will happen if I connect pin 1 directly to the ground. |
#10 |
It's time for u to read some fundas
| speaker protection | audiofan | Solid State | 0 | 19th February 2009 02:35 PM |
| Speaker protection help | ronjodu | Chip Amps | 9 | 16th July 2007 11:49 PM |
| speaker protection (OR) overload protection | myanmar | Solid State | 7 | 13th July 2006 08:21 AM |
| FS: Niles HDS-6L speaker selector w/ speaker protection. | Spasticteapot | Swap Meet | 0 | 27th May 2006 11:14 PM |
| Page generated in 0.09054 seconds (78.37% PHP - 21.63% MySQL) with 11 queries |
