Old 20th January 2012, 09:42 AM   #11
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
Originally Posted by jazzlap View Post
thank janneman,
Now what will happen if I connect pin 1 directly to the ground.
Pin 1 will be zero volts. The data sheet shows what will happen depending on the pin 1 voltage
See attachment. What does it telll you? Do you know what pin 6 does? (Hint: look at the application schematic...).
jan didden
/Another new issue: Linear Audio Volume 3!
Old 21st January 2012, 04:49 PM   #12
jazzlap is offline jazzlap  Canada
I again,
I made a little mistake with my question about the UPC1237. I realise that I look silly... But what I meant was : By connecting pin 1 to the ground I knew that voltage on pin 1 would be 0 volt but will the other fonctions be OK?
BTW I know what pin 6 does ha ha ha
Thanks again for your input
speaker protection audiofan Solid State 0 19th February 2009 02:35 PM
Speaker protection help ronjodu Chip Amps 9 16th July 2007 11:49 PM
speaker protection (OR) overload protection myanmar Solid State 7 13th July 2006 08:21 AM
FS: Niles HDS-6L speaker selector w/ speaker protection. Spasticteapot Swap Meet 0 27th May 2006 11:14 PM
Page generated in 0.06375 seconds (67.86% PHP - 32.14% MySQL) with 11 queries
