| Chip Amps Amplifiers based on integrated circuits |
Hi DIY friends,
I recently got my hands on (don't ask how) a SANYO LA4645N power amp chip. I was able to download a datasheet for the LA4645 (in Japanese) where I discovered on page1. could be configured to a BTL 2Ch 18W X 2 power amp. I though Great! and scrolled down to see the appropriate test circuit which....wasn't there. The quad configuration is provided and I'm guessing that the 2Ch config. is not a radical departure from the quad. SANYO refuse to help me as the chip is out of production. Can anyone give me any suggestions regarding the 2Ch configuration??...for example, what additional components should be included/excluded to get this thing pumping in stereo. |
#2 |
The rule for bridging (BTL) is that the bridged circuit gives double the power into double the impedance compared to the single channel amplifier.
If the BTL specification says 18W, then the mono single channel will be 9W. But at what operating conditions does it produce 18W? Is it closer to a real 10W or 12W? Meaning you end up with 4 mono channels of about 5W to 6W for each.
regards Andrew T. |
#3 |
That's exactly right Andrew. The incomplete data sheet says the chip can provide quad 4 x 6W into 4 ohm loads or BTL 2 x 18W into 4 ohm loads. I can send over some information of you have time to take a look.
#4 |
No.
You have misinterpreted the datasheet. 18W into 4ohms from the bridged pair is equivalent to 9W into 2r0. Using this figure, expect >~4.5W into 4r0 But this is still based on the ridiculously distorted waveform. The truth for real maximum Power output will be much less. That 5W to 6W of real power output is into 2r0, since it is extracted from the 18W into 4r0 bridged pair.
regards Andrew T. |
#5 |
Banned
How did you recently get your hands on a Sanyo LA4645N?
#6 |
Probably jacked it from a boombox or something.
"Audio grade" components simply means that they failed at a more critical job. |
#7 |
#8 |
Banned
Sweet, I have to get me some cereal with electronic prizes.
| Targa HX-2ch 300 | woody | Car Audio | 1 | 28th November 2011 05:13 PM |
| 2 ch stereo to 2ch mono.....? | JoeDJ | Everything Else | 3 | 9th April 2011 01:49 AM |
| 2ch in 1speaker | Baumi | Full Range | 9 | 17th April 2008 07:50 PM |
| 2ch Mediacenter DAC? | dnilsson | Digital Source | 2 | 17th January 2008 06:24 PM |
| how to bridge 4ch to 2ch? | Nathan2 | Solid State | 28 | 14th April 2006 12:06 AM |
| Page generated in 0.10253 seconds (79.61% PHP - 20.39% MySQL) with 10 queries |
