| Chip Amps Amplifiers based on integrated circuits |
Like the title says. Looking for a mono chip amp.
I have an extra Dayton B652 speaker lying around I want to make it into a portable speaker so I'm looking for a cheap mono chip amp to power it. Any ideas? |
#2 |
How about the TDA2003 - 8-18VDC producing about 10W into 4ohms. Simple and cheap to build. How much power were you loking for??
OK!! I just went and checked out your speaker. It's a thumper!! RMS 75W max so the TDA2003 would barely wake this cabinet up. For what it's worth, there are numerous mono chip amps out there that pump out the kind of power you're looking for. Just type some search terms (mono, 40W, BTL chip amp) into google and see what you get. Failing that, go to the National Semicon, Toshiba, SANYO homepages and check out what they've got. Last edited by Ramlee; 6th January 2012 at 06:32 AM. Reason: update |
#3 |
Why restrict the search to BTL.
Any 50W to 70W chipamp could be used without resorting to BTL.
regards Andrew T. |
#4 |
You're going to struggle to get much power with an 18V supply.
You're going to need to bridge two amps or use an SMPS to increase the supplies. Radio-Shack did a cheap In-Car Booster Amp that runs from 12V and gives about 40W. |
#5 |
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
TDA 2004 work bridged easily.
#6 |
I've got one of the Radio Shack bosster amps that you can have for the P&P. I think it was based upon the TDA2004. It's working but the original input leads have been removed. You will need to tinker with the attenuator resistors at the inputs as it was intended to be driven by a power amp (all-be-it a low power drive).
#7 |
#8 |
He did not place a voltage restriction.
He wants a chipamp to drive a 75W speaker.
regards Andrew T. |
#9 |
He wants it portable which limits it a bit.
| 0.5-1.5W mono chip amp | trzn | Chip Amps | 29 | 25th April 2010 06:45 AM |
| how to wire Dual Mono chip amp Kit | merickrc | Chip Amps | 11 | 22nd March 2009 05:39 PM |
| how to connect stereo DAC chip to mono application | gene | Digital Source | 3 | 9th December 2001 09:32 AM |
| Page generated in 0.08583 seconds (75.86% PHP - 24.14% MySQL) with 10 queries |
