| Chip Amps Amplifiers based on integrated circuits |
#11 |
Is automatic gain control (AGC) fitted?
Could the AGC be switched off? or giving too high an output signal?
regards Andrew T. |
#12 |
I don't think there is any AGC installed.
#13 |
The gain is given by the speakers attached !
![]() But...I think that the problem to be overcame is to be found where Guitar 89 has pointed it : if the amp picks some unwanted signal , maybe that is to be investigated . I think that great corporations like Sony make such indestructible products if they are not worked beyond their purposes My English today is...TOO MUCH !!! ![]() If the socalled DAP is a cheap PC not engineered for good sound , that is a cause. Poor supply ( decoupling ) and some junk traveling along the lines . Because...the gain is never enough !! Some Gain-BW product may tell the truth ..
#14 |
hey yo, Mr. pico tony ! Well.... i think it wasn't power supply problem, just some hissing from the chip itself.
I think also contained some RF/EMI noise, since the enclosure itself is not shielded. The gain is also too high for me. At least what I thought is to increase NFB for better THD, etc. |
#15 |
So you may try that odd value resistor -2K7 - at the input of the amp , to form a an RC filter together with a 1nF cap...well ,I see there just one already
![]() 3K9+3n3 ! Did you remove the emitter of the transistor at the input joint ? I see many 'Cdp tweakers' often remove the mute transistors at the output ![]() Now ; you reported the fact that the amplifier is not shielded ...shield it !! Perhaps the whole pcb containing amp's circuit is too big because it houses also radio and cd traces and components ? Rip it ! I remember that IC ( Ba 5417 ) being very ( fairly )good , capable of producing a loud bass...with 4Ω woofers and 2nd order lowpass . Bye !!! |
#16 |
haha, I agree that it is very capable !
For your information, the input transistor is remove. argh.... I have to find a metal case for it X.x |
#17 |
sgrossklass, I have done trying with 2.7k resistor, and no problem seems so far (tested few minute only though)
The hiss is reduced significantly, nice sound is retained though. However, The amplifier isn't sound nice when using direct PC soundcard (compare to other amplifier), however when i use a good quality external soundcard, its sounds nice. Does this have relation to input impedance ? Maybe the soundcard was driving the amplifier hard ? I'm also thinking to bypass headphone, how should I connect ? Could I just bypass C234, R219, L201 ? means can I connect positive side of C134/234 to positive post of each speakers ? (My main purpose is because those component leave the main circuit very far, wanted to dispose of them for smaller board) |
#18 |
Measure it and compare to the measurement/s from your other source/s
regards Andrew T. |
#19 |
andrew, may I know what you mean ? and how to measure ? what to measure ^^
#20 |
Measure the mVac from each of your sources when they reproduce the same signal level.
regards Andrew T. |
| Gain adjust on an Adcom 545. | K-amps | Solid State | 1 | 11th December 2005 12:39 AM |
| adjust gain of Brian GT's 3875 | moreismore | Chip Amps | 0 | 23rd November 2005 04:33 PM |
| Krell PAM-5 gain adjust | JeroenDortmans | Solid State | 0 | 11th August 2005 03:49 PM |
| Gain adjust? Where? | jimbo1968 | Chip Amps | 5 | 30th June 2005 04:56 PM |
| Page generated in 0.10226 seconds (77.45% PHP - 22.55% MySQL) with 11 queries |
