MyRef Integrated Solutions - Page 13 - diyAudio
Old 4th March 2012, 11:50 AM   #121
bcmbob is offline bcmbob  United States
Hi Andrew, Your clairvoyant. Those are the same questions I was thinking about asking as you made your post. The longest lead will be from the outer-most MyRef to the JC-2 and it is twisted. I've been wondering how much I would gain by carrying that through everywhere. The Neotech OCC is really stiff but I could make it so the "Y" is equidistant between the signal and ground tabs on the MyRefs.
The other question I was considering (now we are in the weeds) is how important is to have the same type of wire in both the signal out and the ground/return. Iv'e seen several DIY interconnect designs that use different sizes and metals.
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 4th March 2012, 11:53 AM   #122
you're
Copper is my friend.
Solid core wherever possible.
Just thick enough to carry the current.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 4th March 2012, 12:51 PM   #123
I asked the gurus at Parts Connexion and Sonicraft for their recommendation and they both said 20 awg for connecting the boards and 14 awg to signal out posts. I bought a bunch of silver plated stranded copper from ApexJr in 20 and 16 to play with also. It will be fun to see if I can hear any differences.
Here's a pic of one experiment. Braided silver 30ga - have same in copper but waiting for some flex Teflon tuning to arrive.
Bob M.
Old 18th March 2012, 02:38 PM   #124
Some good progress to report.
All components are mounted and fully functional. I tried to use twists where possible but wires are short. Placed the furthermost MyRef feed under the other one and shortened the output leads to the posts.
I mounted pins on the LighterNote, a screw terminal on the JC-2 and each of the signal "Ins" on the MyRefs.
Note: 90 degree angle on LN signal in.
Here's how the cat-6 cable attaches to the LN and runs under both the JC-2 and the transformer can.
....and the other end.
I didn't do as much "wire sound" testing as had been planned. Everything other than the red out to posts is ApexJr silver plated teflon stranded copper. I did notice some "over brightness" with the solid silver interconnects.
Bob M.
Old 18th March 2012, 03:22 PM   #125
Here's the latest on the music server. Will probably shorten power cable to 2.5" HD. That is for system (OS) files only as an external USB box will hold all the media.
The base of the DAC chassis ended up being a separate unit. I might combine them later to avoid an external link. Just got the kit for this DAC yesterday and have not started to populate. It's the Dario Inserra favorite I mentioned earlier
Temporarilly using a Lexicon Omega on a 16' coax from my HT receiver to feed it and the integrated, Sounds fantastic!
I see a ventilation challenge coming forth that will probably dictate more separation than I had originally thought. I bought a pair of 70mm low noise fans but haven't figured out how I will use them yet.
The white card shows the size of the other DAC that's still being worked on. The transformer has dual voltages that will power either unit.
Please excuse the fuzzy pictures. Not on my best game this morning
...and yes, I'm getting tired of looking at dirty grey primer.
Bob M.
Old 18th March 2012, 04:12 PM   #126
Reality first!
ClaveFremen's Avatar
Bob, I envy your ability with cabinets... fantastic work!
Just one suggestion: keep some space for and additional PS in the DAC one
Dario
ClaveFremen "Bailando Salsa en el Sietch"
Old 18th March 2012, 05:37 PM   #127
Thanks Dario - Having fun with both the cabinets and the electronics. I will check in on the DAC thread to get the latest and greatest trani. I bought the one shown to power the WM8740 unit several months ago but will upgrade to R-Core a bit later.
Bob M.
Old 18th March 2012, 05:48 PM   #128
Reality first!
I was referring to a discrete shunt regulator for the analog part...
I bet you can guess which one I'm referring to...
Dario
Old 18th March 2012, 06:02 PM   #129
Yea, I'll get there by and by.
Bob M.
Old 24th March 2012, 10:11 PM   #130
DAC ADDED
After another struggle with some more silly mistakes (see saga starting here: DAC 2496 (AK4393) DAC KIT With CS8416+AK4393+5532
I got the Mini 2496 DAC assembled and operating. Most everything is mounted with double sided foam tape for now. Several mods and additions have to be made before optimum sound and perminent placement is achieved. Will trim transformer wires, move power LED to front and get two switches that match a bit later.
How does it sound - FANTASTIC. Please see the thread above to read all the raves. Unbelievable sound quality from a small piece of equipment.
Bob M.
WTB myref rev c amp anonomouse Swap Meet 1 26th July 2011 01:34 PM
MyRef-C BOM Consolidation PLEASE bcmbob Chip Amps 3 23rd September 2010 11:45 PM
MyRef C parts for sale madisonears Swap Meet 2 18th August 2010 05:06 PM
MyRef Rev C or Amp 5? preiter Chip Amps 2 30th January 2007 06:28 PM
Troubleshooting the LM3886 MyRef Groundloops Chip Amps 3 1st April 2006 08:21 AM
Copyright 1999-2017 diyAudio
