MyRef Integrated Solutions - Page 12 - diyAudio
Old 11th February 2012, 04:07 PM   #111
Reality first!
ClaveFremen's Avatar
Bob, impressive job!
Very nice, maybe a bit overkill...
Just one thing, do you have space for the Fremen Edition PCBs?
they're 100x114mm
PS
Originally Posted by bcmbob View Post
The signal after the pre passes through Neotech solid core wire.
If it's Neotech OCC, did you take care of determining the right direction?
That cable is directional
Dario
ClaveFremen "Bailando Salsa en el Sietch"
Old 11th February 2012, 06:15 PM   #112
bcmbob is offline bcmbob  United States
Thanks Guys. It's been great fun.
Dario,
I remember that conversation about the Neotech. That's why I reinstalled the two pin signal in socket (gold) on the MyRefs. Once everything is in and working I'll do some of those comparisons. I have not yet found the gold male faston tabs to mount on the boards - maybe someone has a link. I'm also going to give the "angle hair" solid silver a try.
In terms of overbuilding - I agree. I still haven't determined if the larger discreet toroids actually make an audible difference. The 3"x3"x1/4" frame will hopefully eliminate the need for separate heat sinks. The transformer shield has more to do with the computer (matching chassis) that will sit on top, than the amp itself.
Depending on the output of the FE, a simpler straight forward buffer might be a good alternative to the JC-2. Remember the only reason for the JC-2 is the low efficiency of my speakers.
With fewer transformers the soft-start may not have been absolutely necessary. But when the occasional guest comes by, all those clicks and LEDs flashing gives me the chance to impersonate someone who really knows what he is doing.
Onward and Upward !
P.S. I'm planning to do a new build - maybe even back to monoblocks - for the FE.
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 11th February 2012, 10:49 PM   #113
Reality first!
Fine
They're indicated in the BOM, BTW Mouser 534-1287
Dario
Old 3rd March 2012, 03:12 PM   #114
Default Well worth the wait.
Hi All !
Well after a long delay, the pieces of this project have finally come together. Calibrating the LighterNote took longer than I had hoped due to the fact that I apparently fried two of the LDRs on the board. Problems continued till I took the time to re-heat a bunch of points and install gold posts on the LN in/out terminals. Everything finally fell in place.
The results? Nothing less than glorious. The absolute clarity of the LighterNote pushes the JC-2 pre to feed the MyRefs to a quality of sound I have never experienced in my home. Period.
In the photo you can see my fifteen year old DIY reference speakers (Vifa and Peerless drivers - Leap custom X-over) flanked by the newer Sunflowers. The room is twelve feet wide and the SFs sit a foot and a half from the side walls. When playing the system through the inner speakers, instruments appear clear and distinct outside the Sunflowers. The dept of stage is more than I had hoped to achieve.
I intend to hard wire all internal leads eventually, but added a variety of posts and terminals and built a separate module to be able to do some "wire sound" testing. Currently there are about five flavors in the arsenal ranging from single strand solid 30ga silver through a couple boutique copper types.
This photo shows the volume and balance pots attached to the LN with cat-6 cable.
Here (bottom of pic) you can see the single strand silver wire in an interconnect experiment.
Fabrication of the matching chassis for the media center computer has started. (love those flac files) There will be at least two shielded modules - one for the MB/PS/Hard drive and a second for a DAC fed directly from the motherboard via S/PDIF. ....Water cooling -???
Yes, That is BONDO
The integrated amp should be completed by the end of next week.
Bob M.
Old 3rd March 2012, 06:21 PM   #115
Reality first!
Impressive...
Good work, Bob
Dario
Old 3rd March 2012, 06:55 PM   #116
udailey is offline udailey  United States
very sweet! Glad this project is nearly done for you. What's next? DAC?
purchase LDRs anytime Also try my Resistor Replacers or LDR based Input Selector Email me. diyldr@gmail.com
Old 3rd March 2012, 09:58 PM   #117
Thanks guys.
I thought I had the DAC completed but found out (again due to some cold solder joints) I fried one of the WM8740 chips. This was my first complex surface mount attempt and I made some noobie mistakes. The supplier (Jim's Audio - eBay) graciously offered to do the replacement and repairs. Hopefully it will be back by the time the second chassis is done.
Here is a posting from a different eBay supplier but it's the same design.
DAC DIR9001+PCM2706+WM8740 Kit (Coaxial + USB)WLX-1 | eBay
If I have any difficulties I might try the Mini2496 that Dario and friends have been perfecting over the past few months.
DAC 2496 (AK4393) DAC KIT With CS8416+AK4393+5532
Bob M.
Old 4th March 2012, 09:16 AM   #118
squalor is offline squalor  United States
squalor's Avatar
Gee, it looks like the wire from the PCBs to the speaker terminals and RCAs is less than an inch long. Good design !
What kind of disk player is that ?
Old 4th March 2012, 10:58 AM   #119
squalor,
Thanks, I'm trying to keep all signal wires at a minimum. That's on of the benifits of using the LighterNote as the signal does not go through the volume and balance pots. Those pots use a small current to adjust the resistance of the LDRs on the board and eliminate mechanical contact (the wiper) in the signal path. When completed 90% of the signal wires will be 2 inches or less.
The CD player is a modified Sony PS-1. As the story goes, a rogue engineer decided to design a DAC chip with the characteristics of a tube amp and came up with the AKM4309AVM DAC Chip. Many have compared it's sound to players costing several thousand dollars. Unfortunately, Sony used that chip in only one version of the PS-1. Here is a link to the mods
Mick Feuerbacher Audio Projects
...and the extensive thread on user results.
Playstation as CD-player
Bob M.
Old 4th March 2012, 11:20 AM   #120
Short connections are great.
Have you thought about twisted pairs?
Try to work out what route the Signal Ground must follow to minimise the loop areas.
regards Andrew T.
Sent from my desktop computer using a keyboard
WTB myref rev c amp anonomouse Swap Meet 1 26th July 2011 01:34 PM
MyRef-C BOM Consolidation PLEASE bcmbob Chip Amps 3 23rd September 2010 11:45 PM
MyRef C parts for sale madisonears Swap Meet 2 18th August 2010 05:06 PM
MyRef Rev C or Amp 5? preiter Chip Amps 2 30th January 2007 06:28 PM
Troubleshooting the LM3886 MyRef Groundloops Chip Amps 3 1st April 2006 08:21 AM
Copyright 1999-2017 diyAudio
