What if I screw up a speaker? - diyAudio
Old 16th September 2003, 11:10 PM   #1
S.C is offline S.C  United States
Send a message via ICQ to S.C Send a message via AIM to S.C
Default What if I screw up a speaker?
What if I screwed up a speaker when I connect the amp? What do I do? I find out the bigger speaker ( mostly two speakers on the bookstxxx speaker, small for high and big for bass) of my AWIA SC-51 didnt respone. Cuz my carefulless.
Addiction how to test the DC offset if I only have two 51ohm resistor?
btw I used two 51ohm got a 15.xx mV DC offset.
Old 17th September 2003, 12:13 AM   #2
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Default Re: What if I screw up a speaker?
So how do you know you have 15.xx mV DC offset?
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 17th September 2003, 12:26 AM   #3
I put the mutimeter's two point one on each terminal( the ground and the signal) + two 51 ohm resister parallel to it.
Old 17th September 2003, 12:59 AM   #4
You don't need any resistors to check the offset. Just measure it between the output terminals.
www.audiosector.com
Old 17th September 2003, 01:18 AM   #5
oh thx. anyway, I screw up a speaker, can I fix it? It is pretty out
Old 17th September 2003, 01:23 AM   #6
Check the resistance of a speaker with multimeter. If it shows infinity or short, it pretty much means you screwed up the speaker.
Depends on a speaker, some are more or less easier to fix, but sometimes it's just not worth it.
www.audiosector.com
Old 17th September 2003, 01:31 AM   #7
the left one is 7.8-7.9Ohm, but the right screwed up one only have 1.2Ohm. Also I find out the screwed up one dont bounce like the normal when I push the speaker thing down.
Do you think I can order a set of same size new speaker and install it to the housing?
Old 17th September 2003, 01:37 AM   #8
Sometimes you can.
www.audiosector.com
Old 17th September 2003, 01:43 AM   #9
When you mean sometime, are there some pros, and cons?
Awia SC-51 it is pretty old , the speaker mode code is
82-994-601-01
8Ohm NOM. 10W
MAX. 35W
Old 17th September 2003, 01:44 AM   #10
Only availability and pricing. What are those speakers?
www.audiosector.com
Screw Terminal help Zahrec Parts 4 27th September 2008 04:19 PM
How bad did I screw it up??? n00bguitarist Solid State 6 11th July 2008 12:14 PM
Vintage speaker screw outs to 1/4" plug JayGee Tubes / Valves 1 6th May 2005 10:45 PM
Speaker Screw Supplier Jye Multi-Way 4 7th October 2003 09:26 PM
Glue or Screw? gchrist Multi-Way 40 19th July 2003 09:17 AM
Copyright ©1999-2017 diyAudio
