STK 412-170 amps can they be bridged and run from just upper voltage line?
Old 2nd January 2012, 07:05 PM   #1
rafaro is offline rafaro  Guatemala
Default STK 412-170 amps can they be bridged and run from just upper voltage line?
Have several STK 412-170 and plan to use them as amp modules inside linear array speaker sytems. Need to know if they can be bridged and can they be operated just from the Vh high voltage inputs without connecting the lower voltage lines with pins 2-5 not connected
Old 4th January 2012, 05:02 PM   #2
pacificblue is offline pacificblue  Germany
You have two options to work with one rail voltage only. If the voltage is below 60 V idle and 37 V loaded, connect pins 2 and 5 and forget about pins 1, 3, 4 and 6.
If the voltage is above either of those values, connect V+ to pins 1 and 3, V- to 4 and 6, so that the comparator always switches the power stage to the high voltage pins. Leave pins 2 and 5 open.
You must be aware that this approach leads to much higher power dissipation than the chip was designed for and heatsinking will become the limiting factor.
The same goes for bridging. Yes, they can be bridged, but you must expect even higher heat dissipation.
If you've always done it like that, then it's probably wrong. (Henry Ford)
Old 4th January 2012, 07:11 PM   #3
Default How difficult is it to keep original dual voltage design?
have the dual voltage transformer but seems that a dual voltage design would be too complicated?? Where can I get the design schematic/PCB for this part of the design? I am willing to try it as a class G amp with assistance
I do need about 8 of these units!!
Old 4th January 2012, 07:15 PM   #4
Default Also in bridged mode how to wire?
Want to have that option I will increase heat sinks as needed. Thanks for the help!!
Old 5th January 2012, 04:33 PM   #5
The complicated part is already inside the STK. It takes two power supplies, instead of one, two Zener diodes with resistors as voltage raference for the internal comparator, and another pair of resistors and caps to stabilize the supply for input and bias stages.
You have PM.
STK 412-170 amps can they be bridged and run from just upper voltage line?Hide this!Advertise here!
Why do most 2 channel amps run hot when bridged? chipper Car Audio 8 19th September 2010 05:00 PM
What about big IC amps, STK****? jol50 Car Audio 31 29th April 2009 03:56 AM
STK amps 4 5.1 Excluding LFE nz_ic_amper Chip Amps 0 16th October 2004 08:38 AM
What do I need to modify to run Zenv4 off lesser voltage? DrewP Pass Labs 23 20th September 2002 12:16 PM
Copyright ©1999-2017 diyAudio
