| Chip Amps Amplifiers based on integrated circuits |
Ok I built my TDA1557q amp and i using the design
![]() *but - i not have 270nf but i have Replacement i use 240nf - and I do not put resistance 10k - and Finally I do not use pin 12 *THE probleme is : TDA1557Q IS WORK BUT I hear the voice of pure in the case if the sound is low but the performance is very low and when you lift the voice I hear a little voice very annoying and output power DC does not exceed 2 volts *Note that the source of electricity or a car battery from 14 volts to 16.5 volts |
#2 | ||
Do you have a volume potentiometer with a metal case? Connect the case to ground. Connect the potentiometer ground with a separate wire to the amp. Don't daisy chain it, like a wire from the input to the pot, then to the amp. Do you have a ground loop? Connect the source to the same grounding point as the amp with as short and thick a wire as possible. Insert a small resistor of 10 Ohm or less, between signal ground (pin2 and input) and power ground (pins 5 and 6 and power supply). Does the internal protection produce that noise? Check your heatsink temperature. Make sure the heatsink is big enough and thermal grease is applied. Make sure your speaker impedance is 4 Ohm or higher. Make sure that there is no short in the circuit. Do you measure those 2 VDC between the speaker pins? That is too high and may cause the speaker protection to work. Or do you measure those 2 VDC from speaker pin to ground? That is too low, and either the speaker protection is already working or the supply voltage is too low, the mute switch is not working correctly or there is a wiring mistake.
If you've always done it like that, then it's probably wrong. (Henry Ford) |
#3 |
Did not tell you for information to be good in the beginning but after 3 seconds after you turn the sound becomes annoying
In this case if the piece cool |
#4 |
I'm guessing some, owing to lack of a good data sheet and the language issue, but...
1. perhaps the mute pin , pin 11 should be tied high...I can't tell if it has an internal pull-up from the abbreviated data sheet. 2. Do you have enough heat sink on the part? If it gets too warm, it will thermally shut down. |
#5 |
thank you guys
| Need help debugging my TDA1557 amp. | cepa | Chip Amps | 3 | 13th February 2011 11:19 AM |
| Car amp killing battery or car | xstation360 | Car Audio | 10 | 17th December 2010 09:09 PM |
| distorted & hiss sound after "add aux-in" to my old car stereo | reko | Car Audio | 2 | 2nd March 2008 02:49 PM |
| Fostex or Car Speakers for My Tube Car Amp | Craig D | Tubes / Valves | 1 | 30th December 2007 07:01 PM |
| Want to build car amp to run a couple of 12" subs | menaztricks | Chip Amps | 10 | 5th November 2005 04:39 PM |
| Page generated in 0.08085 seconds (82.86% PHP - 17.14% MySQL) with 10 queries |
