| Chip Amps Amplifiers based on integrated circuits |
Hi
I am planning to build LM4780 based Monoblock. Now I am just preparing list of materials required for build, and making preliminary calculations. By my calculations (using 2X22V, 400VA toroid, and using 1 chip per channel) heat sink from Conrad Heat Sinks MF25-100 with thermal resistance 0,37C/W should be sufficient. My biggest concern is chassis layout. My idea is to use MDF for chassis to keep cost low (I have material and tools). Dimensions are (W/D/H) 220 / 300/ 100mm (8,6“/11,8“/4“). My concern is will this layout allow sufficient cooling. Front wiev ![]() Bottom wiev, with rear plate. Circular conpartment is for torroid, compartment near heat sink is for AMP board, and other compartment is for PS. Thanks Last edited by CRNIC_IVAN; 30th December 2011 at 05:13 PM. |
#2 |
#3 |
Banned
I don't know about your cooling but I just wanted to say that is a neat design.
I suspect it would be OK, although it's nice to get a good of a layout as you can when passive cooling. If you were worried, you could enlarge the "ovals", or remove material from behind the ovals exposing more fin area and allowing some cross-flow between the ovals while still having the same general appearance. I'm just thinking out loud here so don't change it on my advice. |
| Simple 845 tube monoblock design | cupik | Tubes / Valves | 14 | 17th October 2010 11:06 PM |
| Monoblock design - left and right bank of output devices | lae2 | Solid State | 3 | 5th March 2010 01:19 PM |
| My upcoming LM4780 design | youyoung21147 | Chip Amps | 16 | 17th November 2005 08:31 PM |
| LM4780 Bridged PCB Design | Gcollier | Chip Amps | 3 | 14th February 2005 01:50 AM |
| Page generated in 0.07629 seconds (74.06% PHP - 25.94% MySQL) with 10 queries |
