| Chip Amps Amplifiers based on integrated circuits |
do i need a zobel network on a parallel /bridge Lm3886 gainclone?
thanks. |
#2 |
Probably not, but why don't you just try? Concentra doesn't appear to use it either.
#3 |
Electrons are yellow and more is better!
If you don't have any problems, you don't have to do something about it, but it does hardly any harm. 2.7 ohms + 100 nF, or something like that.
/Per-Anders (my first name) or P-A as my friends call me Tube Buffered Gainclone in work |Thread |
#4 |
>im afraid to try since the amp is working wonderfully.didnt know whether zobel can be use or not.
>this is my second gainclone..first is parallel clone...with zobel.. >btw: is power on "thump" normal? ..i didnt have this on my parallel clone...any cure? thank..analog & per! tone. |
#5 |
look at the binding postsand you will see , small pcb with a r and c, looks like a zobel to me.
#6 |
Just for reference, how much does that cost? I mean with about $60 worth of LM chips, I guess $250
#7 |
Please can you tell me, because I am getting confused : on a bridge-clone, does the zobel go from one of the speaker terminal posts to earth? or two from each speaker terminal down to earth? or across the terminal posts in parallel with the speaker? or what?
#8 |
PhilW have a wery good question.
How do one apply a Zobel network to a bridged amplifier ?? There are two ways to go: A. A zobel-network to ground for each of the "amplifier-arm" in the bridged amplifier. This makes sense and will for sure work. B. Just applie the zobel-network between the two "HOT" amplifiers that makes up the bridged amplifier. This zobel-network will have no reference to ground. This saves you one "zobel-network" and should in teori work just as well. Many class-D amps and other amplifier topologies that are "born" with bridged ouput seems to take this road. However, I have never seen any explanation or test of solution A compared to solution B. I have used B witch seems to work fine. If someone have expirence or pros and cons of one compared to the other, please let us know. Thomas |
| Zobel Network Corrections | fotios | Solid State | 11 | 22nd February 2007 05:03 AM |
| Zobel Network | JiggaD369 | Multi-Way | 9 | 5th May 2005 12:27 AM |
| Zobel Network question | theAnonymous1 | Multi-Way | 8 | 13th May 2004 05:27 AM |
| Zobel Network | nuttinbutSQ | Multi-Way | 6 | 16th March 2004 08:19 AM |
| Page generated in 1.06155 seconds (100.00% PHP - 0% MySQL) with 10 queries |
