Simple question about OP27
Old 17th December 2011, 12:37 PM   #1
franziscko is offline franziscko  Italy
Location: Sicily, the most beautiful island in the world
Question Simple question about OP27
Hi everybody,
first of all, sorry for my bad english, i hope i can explain all i want and you can understand me.
Please, i've searched in the internet but i can't find the right answer.
I want to build a very simple Preamp with op-amps and make some tests with op-amps i have. Because it'is for me a little difficult to build a PCB with a single o-amp, i decided to use only dual op-amps.
So, what is the right equivalent of OP27 but DUAL? (if exist...)
Many thanks to everybody can help me...
Old 17th December 2011, 12:51 PM   #2
search
dual opamps
regards Andrew T.
Old 17th December 2011, 01:31 PM   #3
tvrgeek is offline tvrgeek  United States
If the PCB is causing you worry, might pick up a "kit" preamp board off e-bay, and use the board. Play with decent op-amps, caps etc. Or for far better quality, see what Ron Elliot has to offer. Even generic IC vector boards are pretty easy.
I did most of my playing around picking chips with a clone of a Grado headphone amp for a dual DIP and for smt, a couple of e-bay generic headphone amps.
Build singles is just as easy as a dual. Just build two!
Old 17th December 2011, 05:46 PM   #4
Originally Posted by AndrewT View Post
search
dual opamps
i've searched dual opamps!!!!
Old 17th December 2011, 05:48 PM   #5
No, i don't want a kit.
Old 17th December 2011, 06:24 PM   #6
jcx is offline jcx  United States
Precision Amplifier - Low Offset Voltage - OPA227 - TI.com
TI now owns National so the op amp seach tool shows "audio" LME series parts too - much better numbers than the op27
unless you really need the lowest Voltage noise performance for phonograph Moving Coil preamp then FET input op amps can have advantages - even with Moving Magnet cartridge
Old 18th December 2011, 07:51 PM   #7
I want to use OP27 because Elektor Magazine used many times and says it's one of the best sounding...
Now i want to try NE5534, LME49720, OPA2134, LM6172 and LT1364, i want to hear myself the differences, if exists some...
Thank you.
Old 19th December 2011, 01:53 AM   #8
the original Analog Devices OP27 is pretty old now, was designed for "precision" - low Vos, very high gain, diff pair biased for optimum noise performance with < ~ 1 KOhm circuits with the best possible "DC" specs - excels at sub 10 Hz noise
slew rate is poor by today's standards, likely EMI rectification in the diff pair front end is not as good as can be had today
the TI/BB second source OPAx27 is basically similar
while I don't believe in most "just listen" reports of "sound" for correctly selected op amps I see no reason to go out of the way to use such an odd "vintage" part when all of its specs for audio applications can be bettered, with 20 yrs evolution in semi processing and circuit topology
AD did market the O27 as suitable for professional audio - doesn't mean you should believe it or anyone who may be echoing the datsheet blurb - you can certainly find comments that the OP27 in fact sucks for audio
many here seem to have missed the fact that A/DSL modem, medical imaging applications demand for low distortion, IMD, noise, drove a massive investment in isolated processes with well matched, fast transistors, and increased design sophisitcaion for low distortion at up to 1 MHz with broadband signals
the best of last decade's new monolithic op amps are a meaningful step above "classic" op amps for audio designed in the 1980-90's when properly applied for the circuit - no one part is "best" over all possible audio circuit applications: MC vs MM preamp, DAC I/V, active XO, ...
Old 20th December 2011, 09:49 AM   #9
ok, i understand your explanation.
all the problem is because i have 4 op27 (buyed many many years ago) and it is for me difficult to make a pcb (more simple with a dual opamp).
so, if i can i will try, or i searche for other op. thanks!!
Simple question about OP27Hide this!Advertise here!
OP27. How good is it? mudihan Chip Amps 42 12th September 2006 04:19 PM
A simple question from a simple man. inteificio Solid State 5 17th October 2005 04:00 PM
A simple question sachi Chip Amps 8 6th August 2005 10:12 AM
OP27 Replacement in KG amp? Garbz Parts 7 22nd March 2004 03:11 AM
Simple answer required for a simple question... rabbitz Multi-Way 4 31st August 2003 11:05 AM
