Mackie Powered speaker problem - diyAudio
Old 14th December 2011, 05:18 PM   #1
Default Mackie Powered speaker problem
I have a problem with Mackie SRM 350V2 powered speaker
We used it last week in Christmas parade. It stopped played and power LED flashes now.
I left in in my garage for a few days. I brought it in and while cold it turned on.
I tried a couple of other times and it just flashes.
I managed to get it to play yesterday. Here is what I have found:
1)At low level, it will play for 30 seconds max. If I turn it up at all, it shuts down immediately.
2)With from power indicator disconnected, amp doesn't power up at all.
3)With no input and gain all the way down, I attempted to check +/-15VDC. When I put black probe on ground, pwer light began to flash. When I put second probe on the clearly marked +15VDC terminal light came on and stayed on. that seemed odd because black probe only was connected. I tried a small screwdriver on the same terminal and got same results. I also toughed screwdriver on -15VDC terminal and light began blinking.
Old 15th December 2011, 07:01 PM   #2
Check the fuses.
Ask Mackie for a service manual. They usually give you one, if you state the serial no. of the product.
If you've always done it like that, then it's probably wrong. (Henry Ford)
Old 15th December 2011, 08:29 PM   #3
! is offline !  United States
I suspect a stress fracture of either the PCB, a solder joint, or a component body. Temperature change or pressure points may temporarily complete (or break) the circuit. When/while it is not coming on, probe around gently to see where the circuit is broken.
Old 15th December 2011, 10:44 PM   #4
Thanks very much! Silly me! I recently work on a synthesizer that would play a note just by touching a terminal on the key sensing circuit until I replaced a resistor network. You were right. I insulated my skin and touched around the board and was able to locate a dry joint on leg of a transformer.
behringer powered speaker argonrepublic Instruments and Amps 9 2nd October 2011 12:46 AM
LM3875 speaker pop when powered on JDawg Chip Amps 36 14th September 2010 03:26 AM
Welling HS-8 Powered subwoofer problem.. dan.murray Solid State 0 20th May 2010 07:56 AM
Constuction Help - Booming powered speaker kurtbauer Multi-Way 18 13th July 2007 09:43 PM
Mackie speaker drivers djdan Multi-Way 0 30th November 2004 06:49 PM
Copyright 1999-2017 diyAudio
