Old 13th December 2011, 12:58 PM   #1
maurycy is offline maurycy  United States
Default Tight squeeze. Need help with layout.
I am trying to put my LM3875 chipamp in a new case. Originally, I had only one trafo and one power board but since I got a matching trafo, I am going with what I think it is called dual monoblock setup (though in one enclosure). Unfortunately, adding additional stuff to a small enclosure is a challenge. It is going to be a very tight squeeze. So here are few layouts that I have come up with. Any one better than the other ones? Front of the amp is on the bottom.
Layout 1
http://i1215.photobucket.com/albums/...sc/layout1.jpg
Layout 2
http://i1215.photobucket.com/albums/...sc/layout2.jpg
Layout 3
http://i1215.photobucket.com/albums/...sc/layout3.jpg
Layout 4
http://i1215.photobucket.com/albums/...sc/layout4.jpg
Please do not recommend getting second enclosure for PS because I bought this one over a year or so ago and can't find a matching one now. I also do not have the money to buy two new enclosures.
Old 13th December 2011, 01:20 PM   #2
firechief's Avatar
Heatsink really needs to be exposed to the outside air. If you enclose it inside it will not do its job of keeping the chip cool. Solve the space problem by making an opening in the box so that the heatsink is outside. Kill two birds with one stone.
"You can keep your insurance baby nothing is guaranteed" -Tom Petty
Old 13th December 2011, 01:34 PM   #3
I was thinking about it but the amp needs to pass the WAF (wife acceptance factor). It is not going to be the case with aluminum fins sticking on the sides. Also, there is a lot of holes on the top and I can drill some on the bottom to let the air in and out. Airflow shouldn't be a problem.
Old 13th December 2011, 05:17 PM   #4
...not so sure about that.
That style of heat sink needs a fan.
The fin spacing is too dense to allow natural convection.
They will not work well, even if installed outside the case.
If the case walls are more than 2-3 mm thick , it may be better to just bolt the chips to the case, lets say one to each side wall.
Space problem solved as well....
Old 14th December 2011, 12:35 PM   #5
Thanks for the suggestions. I may go with a different heatsinks. As to the mounting them outside, that's most likely not going to happen. I had this amp in similar enclosure with smaller heatsinks and it never overheated.
So given that I will use better heatsinks and make sure that the airflow is not restricted inside the case, which layout would work better?
Old 14th December 2011, 01:01 PM   #6
I can't see any layouts.
It appears you have not attached them to your post.
regards Andrew T.
Old 14th December 2011, 01:02 PM   #7
Andrew, there are links in my first post at the top.
Old 14th December 2011, 01:12 PM   #8
I would use option 3, gives a bit of separation from the toroids.
I have a similar setup using the same boards, and similar sized heatsinks and they barely get warm on an 8 ohm load!
Someone will probably disagree..................... but it works for me!
Old 14th December 2011, 02:00 PM   #9
kvholio is offline kvholio  Netherlands
kvholio's Avatar
I would go with option #1, but with both amplifier-pcb's/heatsinks
rotated 180 degrees so the heatsinks will be separating the transformers+rectifiers from the amplifier-pcb's.
Braid/twist all ps-wiring to minimise radiation and keep all ps-wiring well separated from the signal-wiring.
But before comitting yourself to a layout by drilling holes in the enclosure
to fasten various components, you could try various options
without fastening the components.
Klaas
Old 14th December 2011, 03:32 PM   #10
I would suggest one of the options attached, using the chassis as a heat sink.
(Even an 8"x4" aluminum plate/bar will work better than that PC heat sink).
The worst 100/120 Hz radiators are shown in blue.
Apart from the other benefits of adding a real filter bank between the rectifiers and the amps, these radiators are shortened in the second option shown.
(But I do not want to start an argument about the 'benefit' of low capacitance here...)
Speaker recomendation for a very tight budget PLEASE Honda Z50M Multi-Way 21 8th December 2011 09:40 AM
how to get tight bass with little overhang loheswaran Multi-Way 7 11th May 2011 02:00 AM
Alternatives to squeeze box for multiple room setup ceebmoj Digital Source 0 28th February 2008 01:09 PM
Tight bearings in Rega RB250 denied Analogue Source 10 12th March 2007 11:25 PM
is there any way you can squeeze more power out of an aleph5? cowanrg Pass Labs 21 22nd September 2003 07:13 PM
Page generated in 0.11451 seconds (82.89% PHP - 17.11% MySQL) with 11 queries
