| Chip Amps Amplifiers based on integrated circuits |
Hi! I'm new member in this forum. Does somebody have an ideea if it can be made a bridge audio amplifier with TDA2050 with singple power supply(asymetric)?Until now I have seen only diagrams with bridge amplifier with TDA2050 but wit symetric power supply; classic version of amplifier with one chip with single and symetric power supply. I have an old amplituner and I mounted to the radio a FM converter and to the amplifier I want to make an upgrade with IC (it has transistors..but is broken down one chanel;pot.are old and I also have to change them.I want to make a new PCB and on the preamplifier module to make this diagram: Hi-Fi Preamplifier
I have two Unitra loudspeakers with 3 sound ways of 8 ohm impedance and the power supply should be 30Vdc. |
#2 |
I can't recall exactly but I know the PASS site shows single ended amplifiers and also shows balanced amplifiers.
I suspect there will be a single ended balanced amp in there.
regards Andrew T. |
#3 | |
| tda 2050 volume control | asbn369 | Chip Amps | 1 | 24th July 2010 06:12 PM |
| Tda 2050+bd249/bd250c | Alek | Solid State | 2 | 1st February 2010 07:04 PM |
| Nr 50 TDA 2050 | fosforo | Vendor's Bazaar | 1 | 19th June 2008 08:36 AM |
| tda 2050 gainclone / balanced input? | Mad_K | Chip Amps | 51 | 10th September 2007 06:40 PM |
| tda 2050 - heatsinking and schem | scaesic | Chip Amps | 1 | 20th June 2007 02:04 AM |
| Page generated in 0.07097 seconds (72.50% PHP - 27.50% MySQL) with 10 queries |
