| Chip Amps Amplifiers based on integrated circuits |
Here ya go.
That's right, work the camera, baby! The hand polish is done. Yes, that's a reflection in the front panel of my GC chassis. |
#2 |
What exactly are you using to polish it? Can it be done with copper too?
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#3 | ||
se |
#4 |
In case of copper, do you need any type of coating to protect it after? I'm using copper panels in my next amp.
#5 | |
se |
#6 |
The slightest finger print will mark copper. The acid from the oils on your skin will begin to stain the surface and the only way to get the marks off again is more polishing. The longer the print is left, the worse it'll get. Commonly handled or touched sections will darken up really fast, rapidly ruining a uniform copper polished surface.
Although every single finger print will show up on stainless, they rub off just as easily without etching. Copper panels MUST be laquered if they are not to look absolutely shocking. My 2c drew |
#7 |
diyAudio Editor
As has been mentioned before, Incralac lacquer is the only thing to use on copper based metals, and it does work.
OK OK here's a place to get it (and some damar for your speakers) http://www.consemp.com/catalog/f.html |
#8 |
I know all that about copper, but I'm after some sort of "weathered" finish. I'm not looking for shiny polished copper, as this will not much the rest of exterior. I'm afer the look you get when the copper pipes are exposed to elements and nothing can stain them anymore.
Is there a technique to achieve that type of permanent finish without further need for lacquers? I noticed that heating speeds up the proccess of getting copper oxidized. When it's evenly oxidized, it shouldn't accept stains from handling anymore. I'm using that type of cork on the sides and frame (top, bottom and fronts) is made with copper bars.
#9 | |
Then, I sanded with 220 grit sandpaper on a random orbital sander. This left much deeper marks than I first thought. I then wet sanded with 800, 1000, and 2000 grit wet sandpaper. After that, I started hand rubbing using a regular O'Cello (cellulose) sponge and Blue Coral liquid metal polish. This came from Wal-Mart. I repeated this process 12-15 times. This is certainly possible with copper and brass, just start with the 1000 grit paper. Once you get the finish you want, clean VERY well with mineral spirits to clean up all the residue that the metal polish leaves. Then clean with a good spray-n-wipe cleaner. Rinse well with water, and dry thoroughly. I then wiped with alcohol to do a fine de-grease. Next, I would appyly a clear laquer, probably a spray. Let dry well, then spray again. Then wet sand with some 1000 grit paper, and spray again. Finally, polish with a paste type auto polishing compound. This is finer than rubbing compound, but has more abrasives than regular wax. I did this with a copper J-Pole ham radio antenna and it looked great outdoors for years. |
#10 |
I watched an artist accelerate the patina on some copper leaf that he had applied to a wall he was painting. He had a couple of spray bottles different strengths of mild acids in them. It was a long time ago but I think he told me he was using copper sulfate (is that an acid?) and some kind of vinegar. He was defiantly gong for a green patina witch I think is more extreme than you are looking for.
To experiment, you could try polishing up some pennies and dropping them in glasses with different concentrations. |
| capacitor porn | federico moreno | Parts | 9 | 23rd January 2007 01:55 AM |
| BIX porn... | Bas Horneman | Analogue Source | 6 | 10th July 2005 08:47 AM |
| to some of you, this will be porn. | noisenyc | Full Range | 56 | 14th December 2004 10:59 PM |
| My GC Porn...... | S.C | Chip Amps | 14 | 27th November 2003 10:39 AM |
| Page generated in 0.11672 seconds (80.08% PHP - 19.92% MySQL) with 11 queries |
