| Chip Amps Amplifiers based on integrated circuits |
Hi guys,
i have made an amplifier based on the LM3886. the design is per the datasheet of the said chip. The dual power supply which I am using have got two large filter caps (6700uf each). I would like to know if I need to put any other big filter caps as near as to the chip itself plz? Thanks for any input |
#2 |
Put 470uF to 1000uF caps close to the chip and 100nF to 1uF directly on (below) the chip.
One of each for V+, one of each for V-. Do not use the basic circuit in the datasheet, the DC blocking cap on the signal input should not be 'optional'. Last edited by discrete; 29th November 2011 at 11:27 AM. |
#3 |
National tells you what Cs is. Where to locate them. Read the datasheet thoroughly.
Have you chosen to add any of the components that National refer to as "optional"? They are not optional to any less experienced builders. Experienced designers can choose to use, or not use some, or all of the optional components. Builders and beginners must use all the optional components.
regards Andrew T. |
#4 |
For RF a very small (surface mount) ceramic (X7R) 100nf or smaller as close to the pins as possible with minimal parasitic inductance.
#5 |
I do not locate RF attenuation at the -PIN.
I prefer it at the input to the PCB connecting Signal Hot to Signal Return.
regards Andrew T. |
| active crossover - need tweeter block cap if using LM3886 ? | linuxworks | Chip Amps | 14 | 25th December 2010 05:01 PM |
| Need Audio Grade Cap for Mute on LM3886 ??? | Droidiphile | Chip Amps | 2 | 5th March 2010 09:37 PM |
| The 'Ci' DC blocking cap in the LM3886 Feedback Loop | speakerguy79 | Chip Amps | 9 | 29th June 2009 06:03 PM |
| LM3886 schem, feedback cap. | Ivarsson | Chip Amps | 6 | 23rd July 2008 12:59 PM |
| P2P LM3886 Power Amp with Hi-Cap PSU (snubberised) | Vikash | Swap Meet | 0 | 20th October 2006 10:43 AM |
| Page generated in 0.07250 seconds (76.86% PHP - 23.14% MySQL) with 10 queries |
