| Chip Amps Amplifiers based on integrated circuits |
I have brought this IC long long ago, so just thought of making a simple amplifier.
I already built it based on the schematic (figure 1) gave from manufacturer. It is quiet compare to TDA7240 i built last time, also prone to radiation (radio wave), but the main problem is that it won't produce music (have some background hiss, interference, etc) Because this is experimental, I use crocodile clip for temporary connection. When it is alone (on board, point-to-point method), the noise is quite low. When I connect the input (C1/C2) leg with crocodile clip, the noise produced is loud and annoying (can't withstand for few more sec) I guess that is because of interference. So I connected an extra resistor across input (C1/C2) to ground (100k ohm). When i connect the cable to input again, the noise is reduced, but you still know it exist and louder than idle noise. Thus I try to connect the input cable to PC soundcard output, No music is produced (weirdly), but when i crankup the volume, the momentary spike of music presented at the output as strongly distorted sound, no other sound produced. ( intermittent peak sound) Any idea what could happen ? |
#2 | |
In the initial few seconds, the sound was idle/ambient, so ignore it. I started to crankup the volume from the beginning, slowly from 2% to about 60%. Then the headache starts. Loud bangs sound occur is the sound, then notice at about 27th second and onwards, the musical part is more obvious, just don't understand why is it distorted to this degree. |
| help please TDA 7386 problem :( | jayan | Chip Amps | 8 | 25th February 2012 07:16 AM |
| TDA 7293 parallel problem ! | Cro maniac | Chip Amps | 5 | 4th May 2010 01:57 PM |
| TDA 7250 load problem? | di4kata | Chip Amps | 3 | 7th January 2009 09:30 AM |
| problem using tda 8920bj | dhinesh_87 | Class D | 0 | 21st June 2007 02:27 PM |
| TDA 1541 problem (ping Jocko Homo) | limono | Digital Source | 32 | 8th March 2007 09:48 AM |
| Page generated in 0.07051 seconds (71.71% PHP - 28.29% MySQL) with 10 queries |
