| Chip Amps Amplifiers based on integrated circuits |
Hello,
I'm working on my first DIY gainclone project, and have a simple question: If I'm using a softstart, is it good practice to still use a fuse on my unregulated 500 VAC power supply? /Mason |
#2 |
Are you using an in-rush limiter, as your softstart device?
If so, the answer is "yes". The in-rush limiter "limits" current flow while the flux field is initially building in your trasformer core upon start up. It does this by introducing a resistance (while the in-rush limiter is "cold). Shortly after power is applied, the in-rush limiter resistance drops (ans the limiter warms), and effectively removes itself from the mains circuit. The fuse is there for over-current and/or catastrophic failure under operation. Don't depend upon the in-rush limiter to "open" and remove mains voltage--this is a function of the fuse, so include it in your design. To respond in another way--if commercial designs use both in-rush softstart limiters AND fuses (and so do good DIY designs....), then you should, too? Yes? |
#3 |
I appreciate the clarification. I plan to use this softstart board from sjostromaudio, but will also utilize a fused power module like this one on my chassis.
Thanks! |
#4 |
That ON/OFF switch combined with Mains Fuse and IEC socket is a good idea.
It allows back panel control of OFF and front panel control, at low voltage, of Standby/ON. The soft start you have chosen is a relay bypassed version. Exactly the type I recommend.
regards Andrew T. |
#5 |
Yep... Considering you're going with a relay bypass softstart (and not a thermistor one, as I had assumed....), Andrew T is giving you good advice.
Go for it....... |
| New Guy...With a question... | jt1 | Tubes / Valves | 2 | 26th February 2010 01:10 PM |
| Tube HW question from a software guy | rgoodnight | Tubes / Valves | 2 | 9th May 2006 09:01 AM |
| Zirclotron: Question for the big guy | Michael Rothacher | Pass Labs | 31 | 7th August 2003 12:35 PM |
| Page generated in 0.07494 seconds (75.70% PHP - 24.30% MySQL) with 10 queries |
