| Chip Amps Amplifiers based on integrated circuits |
Hi there. Maybe this has been discussed before. However is there a listing of comercial amps that use chip transistors? (lm3886 etc. ) I know Rowland, 47 labs, have used.
Both 2 channel and multi channel amps. Sincerely |
#2 |
That would be one long list.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine |
#3 |
Probably all televisions, probably all radio tuners, probably all lower power car audio systems, probably all lofi and midfi music systems, probably all active computer speakers, probably most active speakers. As he said, a very long list.
regards Andrew T. |
#4 |
Some affordable Subwoofers use Chip amp's too. I suspect you would find them in some AV amp's.
Linkwitz Pluto uses LM3886 chip amp's and sounds superb by any standards. |
#5 |
I'm fairly confident that the vast majority of audio amplifiers introduced in the last 30 years use chip amp outputs. It would be easier to list the ones that don't.
#6 |
Banned
So how many of them are using the actual LM3886? I wondered this myself.
I don't think my TV sounds that good, lol |
#7 |
#8 | |
Globug, Assuming you have a flat screen your TV probably does not sound so hot because it probably uses 2-5 watt chip amp's and 10 pence (UK pound) 1-2 inch "fullrange" drive units squeezed into an electronically noisy space that is so small that two gnats would not have enough room to get jiggy with each other. |
| Yet another "Best Loudspeaker" comercial design.. | ScottG | Multi-Way | 26 | 18th April 2007 04:58 PM |
| Chips for Chumps aka "Intelligent Chips" | jackinnj | Solid State | 0 | 15th April 2005 12:37 AM |
| Page generated in 0.08930 seconds (75.67% PHP - 24.33% MySQL) with 10 queries |
