| Chip Amps Amplifiers based on integrated circuits |
I have a small issue that I have noticed with my lm3875 chip amp. At mimimum volume there is a bit of hum that is noticble, but when i move the volume control up a bit it goes away and is dead quiet...just wondering what this might be?. The pot is a 50k Alps before the the lm3875 and internal signal cable is screened.
![]() The dac that drives the amp is a nos tda1541. cheers Paul
" I love cats....but I couldn't eat a full one. " |
#2 |
Hi
1 - Push the pot to the max with DAC connected = Hum or no ? 2 - Have a try shorting the input without the DAC connected, turn pot from the min to max = Hum ? 3 - Maybe your pot is faulty, try another... Cheers |
#3 |
Ok thanks..will try those tonight and let you know the outcome...i was thinking along the same lines.
#4 |
Disconnect all the external links from your Power Amplifier.
Short the Signal Input to the Signal Return. Measure the output noises, both AC and DC. Report back. A surplus RCA/Phono plug can be used as a shorting link. Open up the back of the RCA plug. Solder a short between the Hot pin and the Cold Return. Insulate the back. Label the modified plug as Shorted or 0r0. Keep it/them for future testing. I have pairs of 0r0, 50r, 75r, 1k0, 10k, 100k for testing.
regards Andrew T. |
#5 |
I have a similar issue with my lm3875 monoblocks without volume control or pots installed. When i connect a source via the rca connector i first get a huge hum which quickly reduces to a mild hum and hiss. When shorting the signal input i have no audible hum or hiss. When measuring output noise i get 19mV DC and 0.09V AC. Is this normal? Thanks, Sander |
#6 |
Could be a ground loop.
Have you used a star ground system ? Or is the amp bought in ready made ? I had a similar problem with a mixer and the ground line was too long causing hum.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. |
#7 | |
19mVdc is OK for offset. 0.09Vac is 90mVac. That is not acceptable. It is probably hum.
regards Andrew T. |
| Transformer Rattle & Hum issue - Dynakit ST-70 | brilliantblue | Tubes / Valves | 5 | 26th July 2011 01:47 PM |
| another Hum issue LM3875 | sts9fan | Chip Amps | 43 | 10th September 2007 04:06 PM |
| HELP!- Hum noise on o/p of LM3875 AMP | craigS | Chip Amps | 4 | 7th February 2006 10:55 AM |
| minimum heatsink size for lm3875 | mateo88 | Chip Amps | 2 | 7th June 2004 05:30 PM |
| LM3875, minimum input sensitivity (gainclone) | mAJORD | Chip Amps | 4 | 22nd April 2004 05:42 AM |
| Page generated in 0.08633 seconds (78.01% PHP - 21.99% MySQL) with 10 queries |
