Old 9th November 2011, 12:05 AM   #1
Default Power supply voltages.
(Warning: beginner's question!)
When building a chip amp using a chip which will accept variable voltages, is it best to have higher voltages and lower current or lower voltage and higher current?
Just curious.
Background:
Currently making a little amp with a TDA7370B, running at 13.8 volts. Sounds great to me! Just wondering if it's worth going for a higher voltage power supply (can be a max of 18 volts) when making the permanent PS.
Thanks in advance.
Old 9th November 2011, 12:37 AM   #2
Richard Ellis's Avatar
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
When one designs a power supply, you first determine how much voltage AND current a device will draw. As this chip may indeed go up to 18 Volts this rating is for maximum power output. The ideal or optimum voltage is at the stated 13.8. When you know the voltage you are choosing (13.8) and the current it will draw at that voltage........design the supply to source that voltage and current requirement. The often argued general rule of thumb is to have 1 1/2 times more current capacity than the device can draw.
__________________________________________________ ___Rick.........
Old 9th November 2011, 01:37 AM   #3
nigelwright7557's Avatar
I would tend to go for the higher voltage as this gives a better headroom for transients.
You can get some pretty high transients well before the amp takes too much power.
I got caught out with power amps, my first was a low voltage and clipped horribly before it gave full power.
The next amp I built I increased the supply rails by around 50% and had much better results.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 10th November 2011, 02:31 AM   #4
On a related note how do you determine what voltage to run at when you build an amp based on an op amp. Most op-amps seem to accept a range of voltages. Example OPA627 runs between ±4.5V to ±18V. PGA2310 runs between ±4.5V to ±15V
Do you try to use the highest voltage as possible or 80% or somewhere in the middle? I understand with a higher voltage you can get better dynamic range. What are the trade offs with going with a higher voltage?
Old 10th November 2011, 03:22 AM   #5
Looking at the performance curves of the OPA627 there was only one curve with varying supply voltage....that was the Bias supply to power supply. Not being able to back up any claims by data (That would be alot more performance curves!) ..my "hunch" is THD+n will find a happy voltage somewhere in between. The clipping issue is a hollow one as all one needs to do is choose a loudspeaker with a higher sensitivity rating (SPL in Db), to get to an acceptable Db level.......Any amp will clip, just depends on the volume level it starts clipping (Is it high enough?) Another 'issue' I have with running at full rated voltage, is generation of heat.........got heatsinks??
__________________________________________________ Rick...........
Old 10th November 2011, 05:23 AM   #6
danielwritesbac's Avatar
Originally Posted by Richard Ellis View Post
. . .The ideal or optimum voltage is at the stated 13.8.. . .
That is true of TDA7370B. One of the tripath also uses that voltage.
Is there actually some weird little car that runs 13.8v with the engine on? That's like 1v less than normal cars. Healthy alternators do 14.8v.
Maybe the 13.8v is because the car chip designers live in an RV with a trickle charger? That's a real mobile application with 13.8v.
Old 10th November 2011, 05:43 AM   #7
sofaspud's Avatar
<pedantry> I think 13.8V is the approximate output of a fully-charged car battery. </pedantry>
For the OP: there are no hard and fast rules, and IMO it's worth examining the intended application and datasheet on a case-by-case basis.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 10th November 2011, 04:39 PM   #8
The old LOW tech lead acid batteries gassed profusely when overcharged.
They required regular checking and occassional "topping up".
To avoid this, battery manufacturers were asked to develop a low maintenance lead/acid battery.
We have gone even further and now have zero maintenance lead/acid batteries.
The chemistry inside these NEW technology batteries is quite different from the OLD.
One consequence of zero maintenance and the "no topping up" is that these new batteries do not tolerate overcharging.
The charging voltage and the temperature compensation of same must be very accurately set. 13.8Vdc is that voltage, to maintain the zero maintenance and a reasonable battery life.
regards Andrew T.
Old 24th November 2011, 08:23 PM   #9
Hello all,
Sorry for late reply, but thanks for the answers. I will have a bash at running the amp at a higher voltage than 13.8, see if I can detect any audible difference.
Thanks again!
Old 25th November 2011, 05:49 AM   #10
Really?
Less might be magical.
More voltage might be the opposite.
Its because stuff doesn't sound good overrun.
With more voltage than optimal, expect a harder sound with lower resolution, no increase in full decibels at the speaker, and no benefit whatsoever. Every time you double the power, you get +3db more, and that won't be happening--any increase within the operable range of this chip won't even do 1db more. It would be a fraction of a decibel. There's absolutely no need to increase the voltage on that amplifier. Higher voltage would go with a completely different amplifier.
If you're switching power supplies, try a finer quality power supply, not a higher voltage power supply.
Amplifier power supply voltages audio_tony Solid State 10 18th December 2010 04:54 PM
Power Supply voltages for Sencore LC102/103 Bargainhunter Parts 0 18th August 2008 03:51 PM
power supply help :how to sum voltages on a trans scottericsonon Power Supplies 3 16th June 2008 11:19 PM
Page generated in 0.10993 seconds (81.49% PHP - 18.51% MySQL) with 10 queries
