| Chip Amps Amplifiers based on integrated circuits |
I am trying to use the TDA7468 for a simple preamp. The part was obtained from digikey.
After soldering it up and driving it, there is no output. The output dc is 1/2 the supply, but there is zero signal. I can tell that the i2c routines are working because (a) I get an ack, and (2) I am able to switch the input source correctly. The input source is available at the mux output of the amp. I can also switch the gain as per the specs. But the signal doesnt seem to be getting past the volume and tone control stages. I tried different setting for the mute function but nothing works. Same with the volume. The (badly written) datasheet doesnt say what the power-on settings are. It has some table giving a power on reset input code, but I have no idea how this is used. Has anyone used this or the other chips of the same type? ANy ideas how to fix this problem? Thanks, vkj |
#2 |
Mute Off = Output On.
Volume1 and Volume2 must be set on both channels. So there are four settings for the volume control: Volume1 setting 1, Volume2 setting 1, Volume1 setting 2 and Volume2 setting 2. Volume 1 is before tone control, Volume2 after tone control, setting 1 means channel 1 and setting 2 means channel 2. You can find the Power-On Reset Condition in Table 5.
If you've always done it like that, then it's probably wrong. (Henry Ford) |
#3 | |
I did try both mute off and mute on (Table 14, sub-address 6, value 1/0). Didnt make any difference. I tried a volume setting of 0 for L and R channels, which I assume is "full" volume, 0dB, acc. to the table. Am I right? I dont understand Table 5. It is not referred to in the text. Is it a one-byte command to reset the chip? If so what is the reset setting? Thanks vkj. |
| New (old) Friends | porkchop61 | Tubes / Valves | 9 | 12th October 2009 02:43 AM |
| Hello friends | whoozit | Introductions | 1 | 24th March 2008 04:22 PM |
| Hello To all Friends | SpeakOFF | Introductions | 1 | 27th April 2006 11:21 PM |
| Good by and so long and farewell to you all friends an no good friends too! | destroyer X | The Lounge | 28 | 13th June 2004 09:12 PM |
| Page generated in 0.07129 seconds (72.32% PHP - 27.68% MySQL) with 10 queries |
