My First Build
My First Build
Old 8th November 2011, 08:40 PM   #21
john blackburn is offline john blackburn  United Kingdom
No worries Nurbit.
If you want some good reading try these.
Decibel Dungeon DIY hi-fi index.
Elliott Sound Products - The Audio Pages (Main Index)
Decibel Dungeon is the website that first had me asking "what's a gainclone then?" I have more amplifiers than rooms in my house now and it is all Nuuks fault.
Buy a big bag of the cheapest resistors and make some stickmen.
Resistor man
You will be glad of the twisting and soldering practice when it comes to weaving a P2P amp, and you will have some stickmen so it is win win.
John
Decibel Dungeonhttp://www.decdun.me.uk/ Elliot Sound Proucts ESP http://sound.whsites.net/ All About Circuits http://www.allaboutcircuits.com/education/
Old 8th November 2011, 08:47 PM   #22
Nurbit is offline Nurbit
Hahaha
oddly enough, I have been planning to build some resistor men but I allways seem to end up playing with the amp... strange eh
I have read decibel dungeon several times but haven't seen Elliott Sounds so I'll have a good read though it.
I've done some point to point stuff before but only when I've been in a rush and couldn't be bothered to use stripboard although now I've started etching my own boards I can stop trying to plan stipboard circuits.
I do have another question though....
For my PSU, I've used a 6A rectifier and a 4700uf cap
Other people seem to use power diodes and several caps
Is the rectifier I've used ok and should I add more capacitors? I assume they're used when the amp needs the extra power for a loud bit????
I lied, I have 2 questions.....
How do I add a volume knob to control both amps?
Old 9th November 2011, 07:32 AM   #23
geraldfryjr is offline geraldfryjr  United States
Very Cool,
Just a note for when you make your next boards, You can touch up the spots were the toner didn't stick or lifted off using a Black Permanent marking pen.
Also you can use some heavy card stock as a straight edge mask should you need to touch up any long edges.
I just did my first two boards the other day using the laser printer method and they turned out great even though I did have too touch them up a bit!
Good Luck!!
jer
Old 9th November 2011, 04:17 PM   #24
Thanks Jer
I did actually try touching them up but didn't realise I'd used the wrong pen until it was too late.
I thought I'd used a permanent but hadn't.
Oh well, I know for next time
Old 10th November 2011, 12:09 AM   #25
danielwritesbac is offline danielwritesbac  United States
danielwritesbac's Avatar
Originally Posted by Nurbit View Post
I have noticed that without an input source, the speaker hums like mad but stops when I plug an audio cable in, even with no music being played.
Your input load is missing. Buy a potentiometer.
. . . How do I add a volume knob to control both amps?
Buy a "dual gang" (stereo) potentiometer for your volume control. I'd use alpha B10k but that's just opinion. That makes 10k input load, the line level spec. Quite a few options are workable. Rod Elliot's site has a lot on applying volume controls.
Old 10th November 2011, 12:15 AM   #26
Originally Posted by john blackburn View Post
No worries Nurbit.
Decibel Dungeon DIY hi-fi index.. . .
That's excellent John!
The outcome is usually nice sounding stable amplifiers that don't need an equalizer. Good job!
My First BuildHide this!Advertise here!
What sub to build jasons Subwoofers 1 29th November 2009 09:05 AM
build my first full ranger,let's build another one:a small fullrange high end pc-spea then_dude Full Range 2 30th November 2005 07:54 AM
Do i need to build main supply (240v) filter?Or build power distribution? thomgun_lc Chip Amps 9 16th September 2005 09:52 AM
What should I build first? chipco3434 Multi-Way 1 18th August 2004 10:45 AM
What I build rossco Multi-Way 9 6th August 2003 12:45 PM
Copyright ©1999-2017 diyAudio
