Old 21st October 2011, 12:12 PM   #1
Default TDA 1514
Is it okay to supply the TDA 1514 IC with a “sealed Lead Acid Battery 12V 7AH” as to make the circuit portable? With this circuit.
Your help is much appreciated.
Old 21st October 2011, 04:33 PM   #2
Send a message via Yahoo to Th3 uN1Qu3
The TDA1514 is designed for split supply that is +, ground (0v) and -. For single 12v you'll want to use something like the TDA7396, or for longer battery life, a class D amplifier.
"Audio grade" components simply means that they failed at a more critical job.
Old 22nd October 2011, 02:41 AM   #3
Thanks for the reply sir.....Can you suggest more ideas or amplifier circuits
that can run on a 12 volt battery......Because I want to create a simple
portable PA system which will also serve as my school project.....your help
is much appreciated.....BTW Im just a newbie when it comes to electronics
and my first project was a 40 watt stereo amplifier Im currently on my ninth grade....
Old 22nd October 2011, 07:27 AM   #4
If you want to keep it simple the 7396 is the way to go. Class D requires more knowledge and tools to get it up and running.
The circuit of the TDA7396 is available in its datasheet, and is as simple as it gets. If you don't want the monitoring section you simply omit the circuitry on the diagnostics pin, as for standby, a 10k resistor in series with a switch to the + side of the battery will do. When the switch is closed the amplifier will be on, when the switch is open it will go into standby. For normal, single ended operation (it can do both single ended and differential inputs), you leave the inverting input (pin 1) unconnected and connect the input signal between pin 2 and ground, which in your case will be the negative of the 12v battery.
Old 22nd October 2011, 03:08 PM   #5
Thank you very much for the help sir, I greatly appreciate it. Just one question, what pins of the IC are connected to the PCB, because in the pcb layout 6 pins are only connected to the circuit, but the IC (TDA 7396) has 11 pins.
Heres the link to the datasheet:
http://www.datasheetcatalog.org/data...ics/mXytqv.pdf
Old 23rd October 2011, 09:12 AM   #6
The PCB layout is given as example only, and it's very low quality anyway. This seems to be the norm for ST - they publish PCB layouts for a lot of their parts, but they're almost always unusable due to the poor picture quality. This circuit is so simple it doesn't even need a PCB - it can be easily made on stripboard.
For the typical noninverting configuration without the diagnostic circuit, which is what you want, pins 1 and 4 remain unconnected, 8 is connected via a 10k resistor and a switch to the + of the battery, input goes between pin 2 and ground (with capacitor on pin 2 of course, just like in the datasheet), and the rest are exactly like the schematic diagram shows them.
Old 23rd October 2011, 01:03 PM   #7
Thanks for the help sir greatly appreciated it!
Old 30th October 2011, 12:28 PM   #8
sir where should I connect pin no. 8?
Old 30th October 2011, 12:29 PM   #9
I mentioned it above. 10k resistor to positive side of battery, and add a switch in series if you want the standby function too (so that the amp doesn't stay powered on all the time and drain the batt).
Old 30th October 2011, 12:47 PM   #10
Thanks sir.
tda 7293 and tda 7294 help sagarverma Chip Amps 84 19th May 2012 03:40 AM
Tda 1305 & Tda 1302 hifive Digital Source 1 10th April 2006 09:04 AM
Tda 1029 EWorkshop1708 Solid State 1 2nd November 2005 04:12 PM
Velleman K4040 (TDA 1514) amp problems MrSensitive Chip Amps 4 25th May 2005 01:08 PM
Tda 1543 Chris Digital Source 5 23rd October 2003 10:39 PM
Page generated in 0.09494 seconds (78.63% PHP - 21.37% MySQL) with 10 queries
