GC User tool at Nat Semi
Old 6th September 2003, 06:32 PM   #1
jackinnj is offline jackinnj  United States
jackinnj's Avatar
Default GC User tool at Nat Semi
National Semi put up a user tool spreadsheet for the Overture Series chip-amps on their website:
http://www.national.com/appinfo/audi...gn_Guide13.xls
just plug in the variables in the blue cells and NatSemi does the rest.
Old 6th September 2003, 09:49 PM   #2
Pedja is offline Pedja  Serbia
Before the start, it is not bad to read this.
Pedja
Old 21st September 2003, 10:50 AM   #3
Hybrid fourdoor is offline Hybrid fourdoor  United States
Hybrid fourdoor's Avatar
After reading the Bridged and Parrallel document over at national that correspondse with this tool I discovered that there seems to be a contradiction between the two. In the document it says that in parrallel mode the formula for R(load) as seen by each IC is (number of IC's)*(speaker load), so a 1ohm speaker is like a 4 ohm load with a 4 IC parrallel circuit, however in the excell sheet you can clearly see above that it is doing (speaker load) / (number of IC's) so a 4 ohm load would be 1 ohm to each IC with previous example.
Which one is right?
Old 24th September 2003, 05:20 PM   #4
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
The right thing is that each amp contributes less if there are many in parallel = the amp sees a lower load (higher impedance)
/Per-Anders (my first name) or P-A as my friends call me
Group buy: DCT03 DC trap for big toroidal transformers. Sign up for interest HERE. 65 pcb's in order. 59 paid.
GC User tool at Nat SemiHide this!Advertise here!
the awesomeness of this tool gain wire Equipment & Tools 16 7th May 2009 03:32 AM
Need a tool! Tenson Multi-Way 12 19th March 2007 08:36 PM
Webench Filter Tool at National Semi jackinnj Solid State 2 15th April 2005 06:54 AM
New SMPS Design Tool from On-Semi jackinnj Class D 3 20th July 2004 12:56 PM
Demagnetising Tool/Tool Demagnetiser mrfeedback Everything Else 30 4th October 2002 11:53 PM
