LM1876 from a pc souncard  - Can it be moded?
Old 19th October 2011, 11:04 PM   #1
dmx2020 is offline dmx2020  New Zealand
Default LM1876 from a pc souncard - Can it be moded?
Hi to all,
This soundcard is an old (~1997) Ensonic AudioPCI E1370 which has a separate board for an LM1876 power amplifier.
It is powered from the +12V (4.2A) and -12V lines (0.8A) of the PC PSU.
Looking at the datasheet for the LM1876, here, i see the LM1876 can only give ~8W at +/-12V.
So what mods can be done to the board/PSU to increase power output from the LM1876:
1) Can the +5V and +12V, and -5V and -12V lines of the PSU be joined to to give +/-17V?
2) if 1 is not possible, can the +5V and -12v, and -5V and +12V be combined to give +/-17V? will the low current of the -5v line (~0.3A) be a problem?
3) Change rectifiers of -12V line to give higher current to match the +12V line of the PSU? Will this make any difference, since the LM1876 will still draw the same current as before at -/+12V?
4) Can anything else be done to increase the voltage from the PSU above +/- 12v? (increase power to pin1 of the tl494 pwm regualtor IC of the PSU. etc?)
ta
Old 19th October 2011, 11:26 PM   #2
sofaspud is offline sofaspud  United States
sofaspud's Avatar
I think it'd be much easier to just isolate the chipamp and give it its own power supply.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 20th October 2011, 03:16 AM   #3
! is offline !  United States
Nothing can be done. It has inadequate capacitance, heatsinking, and current from the negative PSU rails to support higher wattage. That it has an amp chip capable of higher output is somewhat irrelevant, you would be better off building a new amp from scratch.
No you cannot join the +-5V and +-12V rails to end up with +-17V. No you cannot do some other odd thing mentioned as #2 to end up with +-17V either, at most you would end up with a +12V to -5V, 17V total difference instead of +12V to -12V, 24V total difference, PLUS you would have a problem with +12V and -5V (and/or -12V and +5V) in that system ground is not centered between the two rails at 0V.
No, modifying the PSU rectifier will not matter, that will not increase power production on that rail.
No you do not want to increase PSU voltage much beyond +-12V because this is needed for the PC operation.
HOWEVER, if you really want to hack it, here is what to do:
1) Remember your upper voltage limit is determined by the two opamps, (formerly JRC but now NJM) NJM4565. Their upper limit is +-18V. Instead of plugging a connector between sound card and amp board for power, use add-on transformer, bridge rectifier, and capacitors. This is required, to add a separate PSU to get higher voltage.
2) Replace the two electrolytic capacitors with some of higher capacitance, and they might only be rated for 16V too. If your off-board power supply has sufficient capacitance you may not "need" to increase their capacitance value, only to make sure their voltage rating is high enough.
3) Remove stock heatsink and put a better one on. How you mount that is going to be the tricky part, anything suitable would have enough mass that it should not rely only on the chip pins, should be mounted to the board or bracket somehow (or maybe the existing heatsink was, but I cannot see this detail being present in the picture).
4) Replace the speaker output jacks with proper terminals, headphone jacks are not suited to high power output.
Realistically, I don't think this amp module is worth the trouble. Considering that the module is probably about a dozen years old, I would just swap in new, low ESR capacitors of the highest capacitance you can get to fit considering how close they are to the heatsink clip and the PCB lead spacing.
Old 20th October 2011, 04:40 AM   #4
Thank you ! for the informed reply. much appreciated.
I forgot to mention one thing in my first post- that is, the chip and PSU are salvaged parts from an old computer and it is no longer used in the PC.
So the PSU can be completly gutted and rewired if required. I really do not want to build another PSU from ground up since this PSU is just lying around with no use.
I can change the heat sink and caps on the chip board without much trouble.
The problem lies in getting the required current and voltage from the PSU. I read on another post that pin1 of the tl494 regulator chip of the PSU can be modded to get around -/+18v output from the PSU. Article is here.
Can this be done? Change the supply to -/+18v as in the article and then change the rectifiers of the -18v side to match the high current of the +18v side???
ta
Old 20th October 2011, 05:22 AM   #5
Th3 uN1Qu3 is offline Th3 uN1Qu3  Romania
Send a message via Yahoo to Th3 uN1Qu3
Yes the power supply can be modded. But it involves some knowledge of switching supplies and you will most likely blow it up first. In essence all you need is to find the feedback pin (either pin 1 or 16 will be used) and connect a pot between it and ground, that will allow you to adjust voltage. However, the transformer may not have enough headroom to provide 18v at low mains while keeping regulation, so you could end up with hum, oscillations and similar issues. You will also need new capacitors for the former 12v and -12v rails in the power supply because the original ones can't take more than 16v.
Plus, negative rails on PC supplies are always very weak, simply because all they've been used for during the whole history of the PC was bias voltages. It's not only the rectifiers but also the wiring on the coil. For that little chip i'd just buy a small mains transformer and call it a day... switching PSUs become worthwhile when we're talking more than 300W.
"Audio grade" components simply means that they failed at a more critical job.
Old 20th October 2011, 11:51 AM   #6
How about intercepting the signal feed into the chipamp and bringing this/these to become line outputs? Then doing the power amp properly outside the PC chassis.
regards Andrew T.
Old 20th October 2011, 10:12 PM   #7
one more thing,
I heard some PC PSUs have muliple +12V power rails. If mine does (i will check), can the rectifiers of one rail be moded to get -12v instead, at the rated current of the +12v rail(i.e.: 4.2A)?
Old 20th October 2011, 10:15 PM   #8
The multiple rail PSUs use the same transformer and the same inductor winding, they simply use several current shunts for monitoring, to avoid overloading the cable that is wired to them. If they used a separate winding on the inductor it could've been modded. Or if you're willing to add your own winding on the output toroid. Remember, for a negative voltage it has to be wired the other way round.
Old 20th October 2011, 10:31 PM   #9
Some modern, semi-expensive ATX12V PSU do have a 2nd winding for 3rd, 4th, 12V rails that could have one of those transformer windings desoldered at the ends and reverse connected but I hardly see the point in buying one, not cost effective... even if you had one it is worth more for use or resale as a computer power supply.
Old 21st October 2011, 12:20 AM   #10
ok, I will use the amp as it is with +/-12V since modifying is too much work for little gain.
The amp will run with +12V @ 4.2A and -12V @ 0.8A. Does it mean the amp is using only 0.8A max from both rails? And the max power consumption would be roughly (24V x 0.8A) = 19.2W ?
What if the current on the -12V was also increased (in someway) to 4.2A. Would the chip consume more power then or still draw less than 0.8A same as before? may be have less distortion since more current is now suddenly available?
ta
LM1876 from a pc souncard  - Can it be moded?Hide this!Advertise here!
PC PSU running a LM1876 on Soundcard dmx2020 Power Supplies 0 19th October 2011 02:41 AM
Moded marrantz 63 bull041161 Digital Source 2 28th April 2010 10:58 PM
Bestbuy Insignia - moded a la Dennis Murphy peter_m Multi-Way 0 23rd January 2008 08:13 PM
Kwack or another clock on pc souncard Ryssen Digital Source 0 27th January 2004 11:44 PM
lm1876 fabpri Chip Amps 4 15th January 2004 01:22 PM
